Thread: How to get Seatbelt chime and Fasten Seatbelt MSG
Results 1 to 10 of 13
  1. How to get Seatbelt chime and Fasten Seatbelt MSG
    Sep 2010
    albania
    I have an european passat and i just get the seatbelt light for 6 seconds after ignition is on than it goes away.
    I wanna have the DING DING sound and the msg on the fiss till i put the seatbelt in buckle.How can i do that?
  2. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Quote Originally Posted by klitoni View Post
    Tell it its a US Passat?
  3. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Sep 2010
    albania
    Quote Originally Posted by caldirun View Post
    its an european
  4. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    46 Post(s)
    caldirun means change the country code in vcds to tell the car its a us model and it'll bleep until you put your belt on
  5. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Sep 2010
    albania
    I have changed the code but i just get the seatbelt light that goes away after 6 seconds.NO message on fiss and NO sound
  6. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    46 Post(s)
    I (think) if you go into your Instrument module you will find the option to change the country. Set it for USA or Canada.
    Oct 2010
    Here And There
    As far as I remember, when you go to recode the instrument panel, you have options for the seat belt chime in with other warnings like washer fluid low etc.
    Are you using VCDS ? When you go to recode the instrument panel 17 it highlights a bubble which lists all the options.
  8. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Jul 2012
    Dubai
    Anyone knows the complete code for it ?
    Seat belt chime and Indication + washer fluid + brakes sensor ?
  9. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Quote Originally Posted by rashidjafar View Post
    There seems to be a myth that you can fit options by recoding the module, if the option is not fitted no amount of coding will enable it.
    IE to detect the seatbelt buckle has been fastened you would need the switch fitted and also the wiring to it!
  10. Re: How to get Seatbelt chime and Fasten Seatbelt MSG
    Jul 2012
    Dubai
    I am sure there is wiring and all switches cz when at ignition it can detect weather m in belt or not.
    So am searchin for codes to enable the all three functions. (Seatbelt,brakes,washr fluid)
  1. seatbelt warning chime sounding with seatbelt fastened
    By tonyandkaty in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-06-2012, 11:41 PM
  2. Please Fasten Seatbelt
    By nick.king in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-02-2011, 10:23 AM
  3. Seatbelt help
    By crimclaret in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-07-2010, 09:00 PM
  4. Question Unusual Seatbelt chime request
    By daniel408 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-05-2010, 04:10 PM
  5. Question Seatbelt light and chime?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 26-02-2009, 03:01 PM
