Thread: VCD Cambelt check
  1. VCD Cambelt check
    Jun 2009
    Telford UK
    Hi All
    Is there a measuring block in VCD to check after a cam belt change
    If so will it show up if the belt is one tooth out..
    Info much appriciated
    Passat 1.9 tdi AWX
  2. Re: VCD Cambelt check
    Pembrokeshire
    22 Post(s)
    what makes you think its a tooth out ?
  3. Re: VCD Cambelt check
    london/ UK
    Engine, measuring block 4 and see the 4th measuring block called syncro angle. The closer to 0 the better...
  4. Re: VCD Cambelt check
    Jun 2009
    Telford UK
    Hi Zollaf
    Cambelt changed 2k ago ...
    Rough running ie idle is is steady but engine is visably shaking more than it was 10k ago
    Something i cant put me finger on yet but it is not right sounds very noisy
    I might take the rocker cover off next and check the lobes... ??
    But laptop was going to me my first stop as thats the easy one first....
  5. Re: VCD Cambelt check
    Pembrokeshire
    22 Post(s)
    i dont know of a way to check the timing as the belt purely runs the cam and has nothing to do with injection timing. however, if the timing has not been dialled in properly then they will run poorly. who changed the belt ?
  6. Re: VCD Cambelt check
    Oct 2007
    Quote Originally Posted by PCDoctor View Post
    Hi All
    Passat 1.9 tdi AWX
    The timing is not adjusted by a tooth on the belt, the cam pulley is released from the camshaft with the crank and camshaft locked into fixed positions. The belt is then tensioned and the cam pulley is locked to the camshaft, unlike other engines, a tooth out is meaning less!
  7. Re: VCD Cambelt check
    Jun 2009
    Telford UK
    Hi all
    syncro angle is moving between 0.0 and 0.5 so good ...
    Time to check those lobes.....
    BUT
    I did notice alternator loading of 40% and nothing was on just engine running and upto temp...
    Is that normal....
  8. Re: VCD Cambelt check
    Oct 2007
    Hi all
    BUT
    Is that normal....
    Alternator pulley clutch, may explain the rough looking idle also!
  1. how to check if cambelt has been changed? on my b6 1.8t
    By ph47jat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-07-2013, 07:09 PM
  2. vcd
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-12-2010, 11:10 PM
  3. Cambelt check up?
    By Av_Dave in forum Golf MK5 - 2004 - 2009
    Last Post: 27-10-2009, 09:50 PM
  4. How To how can i check the cambelt golf 3 93 1.4
    By service_sad in forum Golf MK3 - 1993 - 1999
    Last Post: 06-12-2008, 03:21 PM
  5. Bio-Fuel - check! V8 - check! 1000 bhp - check!.....
    By Sam in forum Chat - Anything with wheels
    Last Post: 03-12-2007, 04:29 PM
