Thread: Servicing
Results 1 to 9 of 9
  1. Servicing
    Feb 2012
    Bradford
    What parts are needed for a full service?
    Looking to service my car end of this month or sometime next month. Can't remember the last time I had it serviced, so this time I'm going to make a note of it.
    Audi A4 2005 B7, 2.0l TDI s line 147 with 7 gears auto, trip, multitronic.
  2. Re: Servicing
    Feb 2012
    Bradford
    Having just checked on Audi's site, here is what is done by them:
    "Major service £299
    Interim service £149
    Cam belt £429
    Brake pads & discs (front or rear) £259
    Brake pads (front or rear) £129
    Clutch (quattro®) £899
    Clutch (non quattro®) £749
    Brake fluid change £59
    Front Wiper Blades £39
    * Privately owned Audi vehicles over 36 months old from date of registration. Up to and including 2.0 litre engines for A2, A3, A4, A5, A6, TT and Q5. Offer may be varied or withdrawn at any time. Prices include VAT at the prevailing rate and parts and labour. Cannot be used in conjunction with any other offer. Excludes Channel Islands.
    Interim and major service inclusions:
    Both the interim and major services include the following (items in bold are not applicable for an interim service):
    Electrics: All lights, warning lamps and horn function check
    Vehicle exterior: Bodywork check for damage; windscreen; windscreen wash/wipe system; wiper blade condition and park position; headlight washer system; mirrors visual inspection/check heating if applicable; top up of screen wash; door locks and bonnet catch check & grease
    Under bonnet: Oil and filter change, check auxiliary drive belts condition and tension, battery check, Coolant level check, clutch & hydraulics fluid level check, power steering fluid check, Air filter clean or replacement (if necessary), Fuel filter (diesel only) or Spark plugs (petrol only) replacement
    Under vehicle: Front and rear brake pads/discs thickness and condition check; engine, gearbox, steering, suspension check; exhaust system visual check for leaks and damage; brake system: visual check for leaks and damage; under body visual check for damage, loose securing parts and for security; front and rear axle check (Quattro models only)
    Price includes parts, oil, labour and VAT. Offer may be varied or withdrawn at any time."
    So the parts needed will be;
    Front wiper blades if needed
    Screen wash if needed
    Oil and Oil Filter
    Air Filter
    Fuel Filter
    Anything I've missed?
    What is the best oil for my car? previously been told 5-30w
  3. Re: Servicing
    Nov 2010
    Bracknell, UK
    Quote Originally Posted by Boxa786 View Post
    I use Mobil 1 5W-30. Local dealer Reading Audi recommended that brand. My car's on a long-life service schedule, every 20K miles. But I regularly check oil levels, top up as needed. Over 20K miles, that's probably equivalent to an in-between oil change.
    > Current: B9 2016 Audi A4 2.0 S-Line TFSI S Tronic. Mythos Black. A connected computer on wheels
    > Previous: B7 2006 Audi A4 2.0 S-Line TDI Multitronic. Pearlescent Black. High low-tech
  4. Re: Servicing
    Jul 2011
    Near Uxbridge
    Have a look at Opie Oils website http://www.opieoils.co.uk/t-recommen...r-or-bike.aspx
    it will give you all the fluids specs you will need; oil, coolant etc. you can even buy a service pack with everything in it.
    They are also very reasonably priced and their service is excellent.
    Neil
  5. Re: Servicing
    Nov 2006
    East Yorkshire
    Doesn't your car's computer tell you when it's ready for a service?
  6. Re: Servicing
    Feb 2012
    Bradford
    Had it serviced from friends and family so the service indicator is not correct.
    Found the cheap oil thread in B6 forums, ASDA doing mobil 5-30 for £35 online and meant to be cheaper in store.
    Thanks neilos100, that's a good link to follow.
  7. Re: Servicing
    Huddersfield, West Yorkshire.
    I'm sure when i buy genuine oil from TPS it's £30.
    May 2011
    london
    Hi Boxa. I was in asda collindale yesterday and it wasn't cheeper instore. Might just b that one. They did do a real nice job of cleaning the car for a fiver though... so time not waisted.
    Sent from my HTC Desire using Tapatalk 2
    Aug 2009
    Reading England
    5w 30 oil
    Oil filter
    Air filter
    Fuel filter
    Pollon filter
    Audi A4 B7 2.0 Tdi S Line 170.
  1. Servicing
    By rob1990 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-04-2011, 03:38 PM
  2. Servicing for A4 B6 1.8T
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-07-2010, 11:57 AM
  3. Longlife servicing vs. yearly servicing
    By 54A4Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2009, 02:45 AM
  4. Servicing ?
    By boogie in forum VCDS - General Questions
    Last Post: 29-09-2008, 09:54 PM
  5. servicing
    By karen198 in forum Chat - Anything with wheels
    Last Post: 18-05-2008, 11:02 PM
