Thread: A6 Allroad front hub torque settings ??
  1. A6 Allroad front hub torque settings ??
    Jul 2007
    Norfolk
    I have got 2 sets of replacement wheel bearings, and a sealey wheel bearing tool set.
    I need to know the torque settings when i fit the new hub allen bolt.
    Also the bearing has 2 inner races one with a 43mm and other has 45mm diameter, i assume the driveshaft has a ridge on it to locate these?
  2. Re: A6 Allroad front hub torque settings ??
    I need the year and engine as there were some changes and is this a rear or front bearing. Regards Peter
  3. Re: A6 Allroad front hub torque settings ??
    Jul 2007
    Norfolk
    2003 allroad tdi, AKE engine, front bearings. cheers
  4. Re: A6 Allroad front hub torque settings ??
    Removing and installing drive shaft
    Installing
    • <LI class=nonenone>Insert drive shaft in wheel bearing housing.
    • Insert both upper links and tighten nut to 40 Nm.
    • Whilst tightening, press link as far as possible towards wheel bearing housing.
    • <LI class=nonenone>Screw drive shaft to gearbox.
      • <LI class=nonenone>Tightening torques:
      • M8 = 40 Nm, M10 = 70 Nm
    • Press home ABS speed sensor in wheel bearing housing and insert wire in holder at brake caliper.
    • Screw on outer joint of drive shaft.
    Note:
    Vehicle must not be in contact with ground when tightening outer joint of drive shaft.
    A second mechanic is required for the next operation.
    • <LI class=nonenone>1st mechanic: Gets into vehicle and presses foot brake
    • 2nd mechanic: Tightens hexagon bolt for drive shaft
    M14 hexagon bolt: 115 Nm
    M16 hexagon bolt: 190 Nm
    • <LI class=nonenone>Fit wheel.
    • Tighten hexagon bolt for drive shaft. Vehicle must be standing on its wheels when tightening to avoid danger of accidents.
      • Give hexagon bolt further 180° turn.
    From the manual. Regards Peter
  5. Re: A6 Allroad front hub torque settings ??
    The drawings for your car show a single wheel bearing not an inner and outer. I've check the model the engine code the year and even the lightweight ali hub assemble and there do not have an inner and an outer. Also referred to in the spares pages here http://www.vagcat.com/epc/cat/au/A6A...47/52/3074369/
    Regards Peter
  6. Re: A6 Allroad front hub torque settings ??
    Jul 2007
    Norfolk
    It is one bearing, but on the inside (where driveshafts fit) there are 2 parts, one a couple of mm larger than the other(if you think of 2 bearings in one).
    The HEX bolt is 17MM, is that a M14 or M16 ?
  7. Re: A6 Allroad front hub torque settings ??
    Wheel bearing
    • Installation position:
    • Large ID of wheel bearing faces wheel hub .
    If you want the drawings email me at info@3DAssociates.co.uk
    And remind me what you want.
    Regards Peter
  1. torque settings
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-07-2007, 06:23 PM
  2. MkIV Golf Wipers Dead Slow on all Settings
    By Jackjack in forum Golf MK4 - 1999 - 2004
    Last Post: 29-04-2007, 08:14 PM
  3. golf 115 ajm default turbo settings?
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-04-2007, 12:46 PM
  4. What settings need to be reset on TDi ECU?
    By Alas in forum Archive posts
    Last Post: 12-02-2007, 11:39 PM
  5. A4 Alarm settings
    By Mark winch in forum Audi A4 - Archive Topics
    Last Post: 15-03-2006, 09:14 PM
