Thread: RCD 510 (Passat B6 - 2.0 TDI - 2006)
  1. RCD 510 (Passat B6 - 2.0 TDI - 2006)
    Sep 2007
    Hello Everybody,
    I have just bought a RCD510 to replace my temperamental RCD300.
    After fitting it, it drained my battery over night, after my initial panicking and cursing, I did some research and discovered that its a common issue as apparently the computer is constantly looking for the old stereo.
    I've read that I need to purchase a CAN-Gateway???
    Is this correct? can I fit this myself? they seems to be a lot of different types?
    Any help is much appreciated, I'm a little lost???
    Scott
    Jan 2011
    Barnsley, United Kingdom
    They are all identified with letters at the end, a, b, c, etc I understand you need one which is e or above the later the better (I think q is the latest) for any other future mods you may do.
  3. Re: RCD 510 (Passat B6 - 2.0 TDI - 2006)
    Sep 2007
    Thank SG77,
    next question
    Is this something I can do myself, or does it need linking to VAG-com?
    Thank you in advance!
    Scott
  4. Re: RCD 510 (Passat B6 - 2.0 TDI - 2006)
    Feb 2011
    Portsmouth, UK
    Hi, The CAN - Gateway is hidden behind the heater control unit in the dash, so its Stereo and heater controls out to get to it, plus it will need coding. So if you can not code it yourself, there are a few comapnies out there that will supply, fit & code the units for about £150 - I had my done on my 56 plate last year, the company (Hazzydayz) fitted the latest version available at that time and they came down from London to my place of work on the South coast and did it all for me and gave me a 2 year warranty on the parts and work.
    2014 VW Golf GT 2.0TDi Bluemotion
  1. Replies: 46
    Last Post: 14-02-2014, 06:03 PM
  2. Question Passat and RCD 510 Canbus question
    By TimS996 in forum In Car Entertainment
    Last Post: 10-12-2011, 01:27 PM
  3. passat CC: RCD 510
    By bubbles61999 in forum In Car Entertainment
    Last Post: 17-09-2010, 01:25 AM
  4. RCD 510 into 2005 passat
    By richiemac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-02-2010, 12:43 AM
  5. 2006 Passat with RNS - 510 MFD
    By nileshdass in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-07-2009, 11:19 PM
