Thread: oil filter bowl draining.
  1. oil filter bowl draining.
    Aug 2007
    I did an oil change on my 2004 v6 TDI the other day,
    I drained the oil and then it started to rain so I left the oil filter change until the next morning.
    When I took the filter top off and removed the filter, the bowl was empty of oil.
    Does the filter bowl empty into the sump when the oil's been drained because whenever I've changed the oil and filter before the bowl's been full of oil ?
    The car starts and runs fine with no warning lights.
  2. Re: oil filter bowl draining.
    Aug 2007
    Nobody have any idea's about this ?
  3. Re: oil filter bowl draining.
    May 2012
    London
    Oil only goes round filter when pump works then oil goes back to sump. So when you undone sump plug and drained oil then you left it for a while and the oil drains back if you change oil filter when you did oil then there would be oil there.
  4. Re: oil filter bowl draining.
    Aug 2007
    Oh good, everythings alright then.
    It's just that I've never seen the filter bowl empty before presumably because I've always opened it a few minutes after running the engine to warm the oil.
  5. Re: oil filter bowl draining.
    May 2012
    London
    that's ok
  6. Re: oil filter bowl draining.
    131 Post(s)
    1979 Post(s)
    I have seen that with failed oil pressure check valves, do you get tappet clatter on a prolonged idle?
  7. Re: oil filter bowl draining.
    Aug 2007
    The engine sounds like it always has, no loud clattering, are you saying that the oil in the filter bowl should not drain into the sump ?
    I've just removed the filter and had a look and it was nearly empty, I last used the car about an hour ago.
    I then ran the engine for a couple of minutes and re-checked and the bowl was about 1/2 full, I was expecting it to be near enough full to the top.
    Where are the oil pressure check valves ???
  8. Re: oil filter bowl draining.
    131 Post(s)
    1979 Post(s)
    In my experience I have to drain the housing with a Pella type pump, the check valves are cheap to buy but absolutely evil to get at, fuel pump and turbo off.
  1. HELP - i'm in the middle of draining a quattro manual gearbox oil.. . ..
    By philfingers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-12-2011, 10:53 PM
  2. Question 2.0 FSI - Draining the oil filter
    By bosric in forum Golf MK5 - 2004 - 2009
    Last Post: 22-05-2010, 07:21 PM
  3. Po;o 02:How do I get the Oil filter element away from the filter body ?
    By Dan Gurney in forum Polo - Derby - Lupo - Fox
    Last Post: 12-02-2009, 07:46 PM
  4. Draining Oil From A3 2.0 Tdi 54
    By jazzindahouse in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-04-2008, 02:44 PM
  5. Changing Camshaft Adjuster Seals without draining engine oil
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2008, 09:55 PM
