Thread: Centre console (around handbrake lever) removal.
  1. Centre console (around handbrake lever) removal.
    Jul 2007
    Hi Folks!
    Does anyone know how to remove the plastic console that the handbrake lever protrudes from on a B5.5? I could probably work it out for myself but if somebody's done it before it might save me from breaking something! Any tips would be appreciated.
    Thanks, Rich.
  2. Re: Centre console (around handbrake lever) removal.
    Jul 2007
    Not to worry - have done it now!
    Just need to replace the handbrake lever now as the spring for the ratchet mechanism has died.
  3. Re: Centre console (around handbrake lever) removal.
    Aug 2008
    Quote Originally Posted by Ham View Post
    Give us a clue, I am searching for the same thing!
    2004 Passat Highline TDi 130 - Bog Standard
  4. Re: Centre console (around handbrake lever) removal.
    Jul 2007
    Quote Originally Posted by TimboUK View Post
    Was a while ago now but went something like this :-
    - remove two screws (one on each side) where main section of console meets the front section near gearlever. Think there are plastic covers over the screws.
    - lift up arm rest and remove the tray from inside, then remove nuts (4 I think) now visible.
    - open rear ash tray and remove two screws.
    - remove main section of console.
    Once you've got this far replacing the handbrake lever is easy.
    Hope this helps - at least you got a reply!
    Rich.
  1. Handbrake Lever
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2009, 10:33 PM
  2. handbrake lever
    By futsysmids in forum 80 - 90
    Last Post: 17-02-2008, 11:39 AM
  3. Center console removal
    By schoey1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-06-2007, 02:38 AM
  4. Centre console removal?
    By orion1210 in forum Audi A3 - Archive Topics
    Last Post: 01-04-2007, 08:53 AM
  5. Audi 80 centre console
    By Andy8legs in forum 80 - 90
    Last Post: 28-09-2006, 01:22 PM
