Thread: remote centeral locking
Results 1 to 10 of 13
  1. remote centeral locking
    Jul 2007
    Hi I have a 97 audi A4 SE and I was wondering if anybody knows if i can hook my car up to remote key locking using an audi key if so how would i go about it? as i am gettin anoyed with gettin wet everytime I go to my car.
  2. Re: remote centeral locking
    Apr 2007
    Lancashire
    Check whether your central locking pump has two vacuum/pressure outlets. It is located behind the boot side trim, on the drivers side.
    If it has twin outlets, and the last letter/suffix of the part number is higher than 'A', your pump has the RF receiver, and you can use the flipkey remote.
    You will have to get the correct remote (2 button '4DO837231' for early saloon)
    You may have to use vag-com or similar to alter the number in your 'central locking module', in order to let the car know that it is accepting RF 'keyless entry' signals.
    It is a better idea to use one of the £25 aftermarket 'keyless entry' kits available on ebay.
    http://cgi.ebay.co.uk/Remote-Keyless...QQcmdZViewItem
    I retrofitted the original flipkey system into my 97 A4, but the range was so poor (by design), that i now use one of the 'rightclick' kits. Alarm, 'full closure' etc all work, the range is far greater, and the car locks and unlocks much faster.
    If your pump is a one outlet 4A0 type, you could possibly use the early RF (non-flipkey) or IR system.
  3. Re: remote centeral locking
    Jul 2007
    thanks very much for that i will have a look
  4. Angry Re: remote centeral locking
    Hi I bought a remote centeral locking system of ebay but dont no how to fit it. Can anyone help
  5. Re: remote centeral locking
    Audidaz68 Guest
    Quote Originally Posted by akmcb View Post
    I fitted mine a month back, i bought the one that closely resembles the exsisting audi fobs,, and its the bomb,,,
    i have an A4 B5 1999 saloon , what model do you have,,, and wheich kit and from who did you buy it
  6. Re: remote centeral locking
    Quote Originally Posted by Audidaz68 View Post
    HI I have a 1996 Audi A4 1900 tdi
    Remote Keyless Entry central lock KE27
    from ebay globe-bargains
  7. Re: remote centeral locking
    Audidaz68 Guest
    did the kit not come with instructions,,,,,
    the kit i got was from these guys and the link is to the KE27 they do so dont know if its the same as your kit
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=75329
    but my kit
    all connects thru the central locking pump/brain that sits in the right and well in the boot,,
  8. Re: remote centeral locking
    but my kit
    No just got the kit itself and two remotes
  9. Re: remote centeral locking
    Apr 2007
    Lancashire
    Fitting instructions used to be available online, but the links now require a username & password.
    You may have to register on the Rightclick site to access them?
    http://www.rclick.co.uk/pdf/audi_a4.pdf
    http://www.rclick.co.uk/pdf/universal_fitting.pdf
  10. Re: remote centeral locking
    Quote Originally Posted by ini View Post
    Thanks will try that now
  1. Remote locking
    By hassan424 in forum 80 - 90
    Last Post: 30-03-2007, 12:32 PM
  2. Passat Remote Locking/Locking
    By TallChris in forum Passat - Archive Topics
    Last Post: 22-11-2006, 01:14 PM
  3. interior lights and centeral locking
    By packdude in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-11-2006, 07:55 PM
  4. a4 remote locking
    By pvs in forum Archive posts
    Last Post: 20-09-2006, 09:44 PM
  5. remote locking
    By roger.morris in forum Passat - Archive Topics
    Last Post: 05-12-2005, 11:29 AM
