Thread: how to code s/h ccu to my passat b5
  1. how to code s/h ccu to my passat b5
    Dec 2008
    Ayrshire Scotland
    Hi ive just changed the ccu in my 03 passat with a good secondhand unit and need help with coding it to my car.I have vag-com and ross-tech cable but just a newbie with it.Since fiting the new ccu the auto wipers have stopped working and the intermittant wipe only wipes once then stops..........i guess these two probs are connected.........any help woukd be much appreciated.
    IAN
  2. Re: how to code s/h ccu to my passat b5
    May 2010
    Devon England
    if you go in to the controller and then in to coding you should see a group of numbers when you hover the mouse over it a box will appear giving you details of the numbers to put in, can i ask what was wrong with your old CCM? you could scan it and write down the coding and then just put that number in, a lot easier TBH
  3. Re: how to code s/h ccu to my passat b5
    Dec 2008
    Ayrshire Scotland
    Hi thanks for that info.....the old ccu had the usual water damage which meant the interior lights didnt work and e/w were intermittant.
    I still have the old unit so will pop it back in and scan it to get the code.Im new to vag-com so really just feeling my way with it.
    Will post how i get on with it. Ian
  1. ccu question
    By scootir706 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2012, 10:40 PM
  2. Replies: 1
    Last Post: 18-11-2011, 08:13 PM
  3. Help- need to replace ccu after water damage and code in replacment unit
    By GeeCee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2011, 05:14 PM
  4. help with ecu / ccu
    By novadan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2009, 09:18 AM
  5. What is in the CCU?
    By bayside blue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-01-2009, 12:58 PM
