Thread: A6 C7 VCDS Tricks
Page 89 of 90 FirstFirst ... 397987888990 LastLast
Results 881 to 890 of 897
  1. Re: A6 C7 VCDS Tricks
    Oct 2015
    Banbridge
    10 Post(s)
    thanks but yes i know about the rocker switch mute but is that the only way to stop this ? i would have thought it could be muted via vcds or app
  2. Re: A6 C7 VCDS Tricks
    Nov 2020
    Helsinki Finland
    The following isn't working for my A6 2012/04, despite setting to 20km/h the camera turns off at 15km/h and turns on again at 10km/h.
    24. Alter the switch-off speed of the Audi parking System[Select]
    [10 - Park/Steer Assist]
    [Adaptation - 10]
    Select Channel 23 and Read
    Change the value from 10 to 20 (Max speed in Km/h - 20 is the highest you can set it to)
    Press Test then press Save
    Maybe there's another setting somewhere?
    My camera control unit details:
    System description: TopView
    Software number: 4H0907428A
    Software version: 0111
    Hardware number: 7P6907441D
    Hardware version: H05
  3. Re: A6 C7 VCDS Tricks
    Jan 2022
    Hungary
    Hello!
    Does anyone know the setting in "Lap timer" mode to display the oil temperature below 60 degrees Celsius?
    Audi A6 C7
  4. Re: A6 C7 VCDS Tricks
    Nov 2022
    Czech Republic
    Hallo Freunde, ich habe eine Frage zum A6 C7 4G LED-Matrix für LED-Tagfahrlicht, das Standlicht ist mit dem Tagfahrlicht auch an, aber die Navigation ist im Tagmodus.Reagiert es irgendwie von alleine oder sollte nur das LED-Tagfahrlicht tagsüber an?. Danke für den Ratschlag
  5. Re: A6 C7 VCDS Tricks
    Apr 2023
    Hungary,Harka 9422
    Hi there!
    I know it is an old thread but who knows...
    I bought an used A6 2013 and i would like to activate the disarme chirp but i dont have the correct value ....
    Could anyone tell me the default value in 46 central conv-10 adaption-channel 63 or the modified one to make it work?mine do not have the correct one for sure..
    Thanks in advance!
  6. Re: A6 C7 VCDS Tricks
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by bb1977 View Post
    Hi there!
    Thanks in advance!
    Looks like the current value in Channel 63 is 7? Have you tried adding 4 to it - making it 11?
    I never tried this on my car - I had a 2012 A6 at the time, so I can't say for sure it works. Have you already enabled the Beep on Lock function?
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: A6 C7 VCDS Tricks
    Apr 2023
    Hungary,Harka 9422
    Thanks for your answer!
    7 is not the original value. I have already tried a few values but does not work.
    I also tried the lock option but doesnt work ....
  8. Re: A6 C7 VCDS Tricks
    May 2009
    69 Post(s)
    Are you sure the alarm siren is working? This is what provides the chirps - if it's faulty, you won't get the beep on lock or the two beeps on unlock.
    Cheers!
    MF.
  9. Re: A6 C7 VCDS Tricks
    Apr 2023
    Hungary,Harka 9422
    Well no,i am not sure but without the correct value is hard to tell...This car is full of surprises. Just changed the gps antenna too....
  10. Re: A6 C7 VCDS Tricks
    May 2009
    69 Post(s)
    The Beep on Lock function uses long coding, not adaptation values. If Beep on Lock isn't working, I'd look carefully at your alarm siren.
    Can you manually trigger an alarm? If so, do you get any sound, or just the indicators flashing?
    Cheers!
    MF.
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
