Thread: De-chroming window trims
Results 1 to 10 of 11
  1. De-chroming window trims
    Jan 2011
    Magherafelt
    I plan on having my chrome window trims converted to gloss black by either painting or having them vinyl wrapped:
    Are the trims easily removed?
  2. Re: De-chroming window trims
    46 Post(s)
    Are you wanting to do them yourself?
    If not, ATM Graphics in Ballymoney does this sorta stuff .. Highly reccommended as I've used them in the past for various bits - easily paid too.
  3. Re: De-chroming window trims
    Jan 2011
    Magherafelt
    No I wouldn't be doing them myself but I'd like to remove them myself and be able to use the car whilst they are being done.
    Is it vinyl wrapping that ATM does?
  4. Re: De-chroming window trims
    46 Post(s)
    I (think) they're only glued on so a bit of heat and some floss etc would take it off - but I'm not 100% on that. They may be clipped/popped on.
    Andy would know how they're attached.
    028 2766 4646
    He can wrap them, I was in once and he was wrapping a 5 series' chrome into black/carbon.
  5. Re: De-chroming window trims
    Aug 2009
    Near Lanark
    21 Post(s)
    have a search through the forum -there are several threads on it.
    Going by those other posts, removing them is a nightmare. You may have to remove door trims and I believe the rear triangular window has to be removed on the saloon.....so I'd expect similar difficult jobs on an estate.
    I just bought some matt black tape and will wrap mine. Had a go this morning and it was looking quite good until I had to trim it and found my stanley blades weren't sharp enough....so pulled that bit off and will have another go soon.
    Looks really good when wrapped and you might even find pics on those other threads.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  6. Re: De-chroming window trims
    Feb 2012
    Bradford
    quick 10 second search found:
    https://www.vwaudiforum.co.uk/forum/s...954#post712954
    Something you could easily do yourself and its meant to be very good quality results.
    Mar 2010
    bangor uk
    The chrome surrounds are riveted on so they would be a nightmare to remove, wrap them on the car and use a very sharp scalpol/hobby knife to trim.
  8. Re: De-chroming window trims
    Aug 2009
    Near Lanark
    21 Post(s)
    Eventually got round to this....well nearly.
    I've done the driver's side tonight and called it quits when finished. I'm using the motorbike so the car can stay in the drive tomorrow. I'm planning on doing the passenger side tomorrow.
    First impressions?....looks superb. Matt black tape on the chrome surrounds. Taking my time, and bought new stanley knife blades to ensure a nice cut.
    Unfortunately, the tape isn't wide enough to do my grill, so I'll either need to get wider tape or cut it from a sheet. Using a wider roll would be much easier I think.
    I'll post a few pics of the finished job over the weekend so keep an eye out for them if you're thinking of doing this.
  9. Re: De-chroming window trims
    Feb 2009
    Essex
    Quote Originally Posted by darich View Post
    Looking forward to the pics and tips, I've got the tape and scalpels, so when the weather picks up it's the next job..
  10. Re: De-chroming window trims
    Aug 2009
    Near Lanark
    21 Post(s)
    Mac
    I've messaged the seller of the tape on ebay to see if he has any wider stuff for the grill. The 50mm tape isn't wide enough to cover the chrome so I need either a sheet (very difficult to fit without removing the grill) or wider tape. Tape would be far easier and quicker.
    Just received a message from the ebay seller (within 30mins of sending question!). He reckons he might be able to get me some cut to 75 or 100mm wide. He also said he knows of a US supplier doing that size so should be able to do my grill soon enough!
    I'll post a few close ups - I made a couple of joints because there were a couple of real tricky bits and partly because I didn't want to waste loads of tape....I only have one roll. So when I made slight mistake, rather than rip the whole thing off, I cut a straight joint and only removed the damaged part. You really need to look for the joint though.
    I'm pretty happy with it.
  1. Question Can I take the chrome window trims off
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-06-2012, 02:03 AM
  2. Question Chrome window trims
    By Alann84 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-01-2012, 11:33 AM
  3. Please Help How to replace chrome window trims ?
    By onionman100 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-01-2012, 12:15 PM
  4. Chroming Window Lining - Golf '05
    By ccs in forum Golf MK5 - 2004 - 2009
    Last Post: 14-09-2009, 10:17 PM
  5. Window Trims
    By stua4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2007, 10:24 PM
