Thread: Help! I don't want to scrap a beautiful cabriolet
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Help! I don't want to scrap a beautiful cabriolet
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Quote Originally Posted by calista View Post
    OK well thanks for that. I don't really have much of a clue because I'm not a mechanic, which is why I signed up to this forum. The only question I haven't answered is whether the radiator gets hot, but I'm afraid I don't know how to tell that.
    I have had two mechanics look at it. They both said they have done as much as they can without spending alot of money. I presume that means that it is a head gasket but they can't tell without spending the money, which is my problem.
    I was really looking for someone who might be interested in helping me to fix the car at a decent price. I should have been clearer on that in the first instance, if at least to avoid the flak.
    Calista, I meant no offence toward you, it just looked like you had ( as so many do ) only joined to extract free help, but had taken a week to respond till now.
    I'm not an offensive falla and apologise if my remarks were taken that way.Your car being a v6 will have 2 head gaskets
    To your car, you can tell if your radiator gets hot by feeling if there is heat coming from it, which will show itself by being warm.
    Sorry , being sarky, a little light hearted forum banter.
    Some checks you may be able to make for yourself without being a mechanic
    1, look into the tank where you put water/antifreeze, which on your car should be under the bonnet near to the windscreen on the passengers side, and see if the water is a clean watery fluid , possibly pink.
    It should be clean pink water.
    If you can see an oily creamy gunk in the water, a bit like mayonnaise you may have an issue with a head gasket.
    If you pull the dipstick for your oil level, on your car this is a large orange ring handled pull stick on the drivers side of the engine, under the bonnet.
    You should find just oil ( clean and gold if recently changed, or maybe a bit black if service is due ). If the oil dip stick shows a lot of the aforementioned mayonnaise you may have an issue with the head gaskets.
    If you open the oil filler cap, on your car this is a round black twist off cap just on top of the engine and almost directly above the dip stick on the drivers side and will have a picture of an oil can on it.
    The oil filler cap may have a very slight showing of the mayonnaise but this can sometimes be acceptable if it is only a slight amount.
    The mayonnaise/creamy gunk I have mentioned is the affect of your engine coolant/water/anti-freeze mixing with the engine oil and emulsification occurring
    This can happen when a cylinder head gasket goes and allows the 2 fluids to meet, and they shouldn't.
    The above checks should be made with the engine SWITCHED OFF AND COLD, for your own safety and should take you less than a minute to complete
    If the above tests seem beyond your own ability or a bit daunting, you really should have the car looked at by somebody you can trust not to rip you off and to give you a qualified opinion
    It doesn't sound like whomever looked at your car has been very helpful and it would be a shame to scrap a lovely cabriolet based on not really knowing if it has a serious problem or a simple sensor/sender issue
    Again if my comments previously made offended you or any other forum user it was not my intention.
    Good luck
  2. Re: Help! I don't want to scrap a beautiful cabriolet
    Oct 2009
    10 Post(s)
    There are may other causes for over heating also ie, dud water pump ,dud thermostat, blocked or malfunctioning radiator or its' hoses, electric faults in relation to the switching on of your cooling fans etc, etc and I don't mean to send you up the head gasket worrying route unnecessarily, so please have a reputable mechanic look at the car informing him that you want a diagnosis first, not a massive bill.
  3. Re: Help! I don't want to scrap a beautiful cabriolet
    Oct 2009
    10 Post(s)
    There ya go , another 8 days and............................................... .................
  4. Re: Help! I don't want to scrap a beautiful cabriolet
    Oct 2009
    10 Post(s)
    Another 7 days...........
  5. Re: Help! I don't want to scrap a beautiful cabriolet
    Pembrokeshire
    22 Post(s)
    and counting.....
  6. Re: Help! I don't want to scrap a beautiful cabriolet
    Oct 2009
    10 Post(s)
    Another 13
  7. Re: Help! I don't want to scrap a beautiful cabriolet
    #17
    I'm not sure what that post by fourringus is referring to.
    I am basically looking for a mechanic who will offer me a good deal to get the car on the road again. Any takers? I live in Islington.
    Maybe he found the right deal
  8. Re: Help! I don't want to scrap a beautiful cabriolet
    #18
    Oct 2009
    10 Post(s)
    Possibly, but I usually do my best to finish off a thread when it reaches a conclusion and thank those who helped.
    I'd wager that this one is just another non courteous, free info grabbing ,waste of rations who never would have used any given advice anyway.
  9. Re: Help! I don't want to scrap a beautiful cabriolet
    #19
    Pembrokeshire
    22 Post(s)
    certainly looks that way. maybe esh is correct and he (or she ? ) found a mechanic and just hasn't bothered to tell us. maybe it was someone on this forum that helped him (or her) you never know. maybe the car is cube shaped and heading for china though, to return as cheap tat.
  1. Attention is it a beautiful sight!
    By 95cabrio in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-03-2012, 11:15 AM
  2. Question To scrap or not to scrap that is the question !
    By texmexrex in forum Touran - Sharan - Caravelle
    Last Post: 12-02-2012, 04:02 PM
  3. Beautiful RS4 Cabriolet for sale
    By RS4Lee in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-01-2009, 12:09 PM
  4. Piccies of my beautiful A4 SE
    By MackemMan in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-05-2008, 11:46 AM
  5. Kitted Cupra K1 Is The Body Beautiful
    Last Post: 27-02-2008, 10:26 PM
