Thread: Audi A6 2.7 TDI Intermittent Electrics
Results 1 to 10 of 11
  1. Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    I have a 2006 Audi A6 2.7 TDI Quattro and from time to time the electrics start blinking intermittently. The headlights, tail lights, instrument panel, MMI, all start flickering, but to date I have not felt that the car engine or power is affected. It happens on rare occasions and to resolve the situation I pull over, turn off the ignition and remove the key and then re-start. it seems to do the to trick, but its not a good feeling.
    If it was the alternator at fault, surely the problem would be a more consistent? is there a fuse that governs the above? The condition seems to be sensitive to the instrument warning panel indicator, as I have noticed that if the windscreen top up fluid or brake pad warning signal (need replacing soon) appears, it provokes the condition above.
    Any ideas?
    46 Post(s)
    Do you have an avant? Could be the rear washer pipe leaking all over the electrics in the boot!
  3. Re: Audi A6 2.7 TDI Intermittent Electrics
    Sep 2011
    Lurking over a keyboard ...
    Another place can be the fuses/electrics in plenum chamber in engine bay, if drains are blocked car tends to get erratic electric problems when water ingress occurs... could be bad earthing as well
    Attachment 16477
    Remove rubber seal highlighted in red, lift cover marked by green arrow.
  4. Re: Audi A6 2.7 TDI Intermittent Electrics
    Sep 2011
    The pipework is behind left boot trim panel, there are also fuses/electric stuff in right of boot trim... some posters have also had lose connections by battery and battery monitor module in spare wheel well in boot...
    Do you have access to VCDS/VAGCOM? scan may help, these are all ideas for fault finding.
    2 0 0
  5. Re: Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    Do you have an avant? Could be the read washer pipe leaking all over the electrics in the boot!
    Yes, its an Avant, but I doubt that its a leaking washer pipe as the condition still prevails in dry sunny weather. Nevertheless I'll keep this in mind and check.
    Thanks for your contribution.
  6. Re: Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    Quote Originally Posted by gupsterg View Post
    Another place can be the fuses/electrics in plenum chamber in engine bay, if drains are blocked car tends to get erratic electric problems when water ingress occurs... could be bad earthing as well. Remove rubber seal highlighted in red, lift cover marked by green arrow.
    Interesting thought. I will check this out and get back with feedback.
    Thanks for your suggestion.
  7. Re: Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    I think Chris meant rear washer... the pipework is behind left boot trim panel, there are also fuses/electric stuff in right of boot trim... some posters have also had lose connections by battery and battery monitor module in spare wheel well in boot...
    Another good suggestion Thanks, will check this out and come back with feedback. I have a VAGCOM cable that I use for my wifes VW Passat, so that should also do for the Audi. Lets see what a scan comes back with. Cheers for now.
  8. Re: Audi A6 2.7 TDI Intermittent Electrics
    Sep 2011
    From the way your original post reads you have had this a period?
    If the rear washer pipe has leaked/split under carpet trust me it won't dry by itself the sponge is thick and water has nowhere to go read the posts here https://www.vwaudiforum.co.uk/forum/s...Washer-Problem but this fault usually effects telematic/mmi functions.
    Once you do scan if there's faults post scan as the super posters crasher/a8 tech and not mention other great posters maybe able to solve by just looking at it, your problem seems wide spread it maybe a control module
    Here is link for SSP 326 which may help with overview of electrics and location of control modules www.volkspage.net/technik/ssp/ssp/SSP_326.pdf
  9. Re: Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    Thanks for the suggestions and references. I will check them out.
    I actually acquired the car end Jan 2012 and prior to purchase had the Audi Centre do a full diagnostics test on the vehicle. Nothing came up then and the fault surfaced around February.
    I will let you know how I get on. Cheers !
  10. Re: Audi A6 2.7 TDI Intermittent Electrics
    Jul 2009
    Garciems, Latvia
    RESOLVED
    Having done all the above, I concluded that the main problem was the connection to the battery where the positive pole connection was loose.
    I have now driven the car for nearly a month and all is well.
    Having taken out the spare wheel housing in the boot well and releasing the battery, I was able to get at the battery and check / tighten all connections in the area.
    There are quite a few connections, so it was well worth while checking and giving them all a slight tighten. The main culprit was the the main + connection which could be slightly moved by hand.
    I didn't find any water problems, but it was well worth while inspecting the plenum chamber in the engine bay as it did need a clean.
    Thanks for everybody's help and contributions.
  1. Audi A4 2.5 TDI intermittent jerking problem
    By SAJ4D in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-01-2010, 03:38 PM
  2. Please Help Audi a4 2.5 tdi - intermittent smoking when idling.
    By audirjb in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2009, 11:10 PM
  3. Please Help Audi 80 TDI 1983 intermittent power loss
    By mjcoops in forum 80 - 90
    Last Post: 17-12-2008, 09:40 PM
  4. Audi A4 1.8T electrics
    By andrew1963 in forum Chat - Anything with wheels
    Last Post: 20-11-2008, 09:53 PM
  5. Audi A4 electrics
    By jasonaudiA4 in forum Chat - Completely Off Topic
    Last Post: 22-12-2006, 10:50 AM
