Thread: Drivers Door Wind Noise
  1. Drivers Door Wind Noise
    Aug 2008
    Somerset
    Hi All
    I have wind noise which is noticable at speeds about 25mph. However the noise doesn't get any worse the faster I go.
    Anyone got an idea what to check first ?
    Thx in advance
  2. Re: Drivers Door Wind Noise
    Ayrshire, Scotland
    18 Post(s)
    Do you think it is coming from the door-window?, if so check the door closes neatly and the alignment looks good, but I had a whistle from my window as they can suffer broken window guide clips which stopped my drivers side window going right up into the seal when closed,
    a quick check, with the window up and door open, place a hand on each side of the glass and push up, if the glass moves further up, it could be a broken guide. You may also see a slight gap right in the top corner of the glass in the seal.
    search on the forum window jamming issues and how to change the guide clip
    Although just re-read and you say it doesn't, get worse with speed, so that could be that theory,
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Drivers Door Wind Noise
    Apr 2007
    I also have this problem, is the replacement clip a DIY job or does it need to go to a specialist ?
    The window does move if i grab it with my hand..
    Audi A6 1.9 TDI Final Edition 2004
  4. Re: Drivers Door Wind Noise
    Ayrshire, Scotland
    18 Post(s)
    You can do it DIY (depending on your tools and skill), I managed to replace the rear one without removing the window mechanism I have a small ratchet spanner I can fit a torx bit into which allowed me to reach inside the door & undo the torx bolt which holds the glass in place then just unclip the slider, clip the new one in and redo the tiorx screw, (tip run the torx screw into the new slider before fitting, it cuts a new thread), but at worst you need drill out the rivits and remove the door subframe to gain assess to the slider
    search other posts for the part numbers and other tips
    regards
    Andy
  1. Wind Noise Drivers Window?
    By quattrodlo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-10-2011, 07:17 PM
  2. Wind noise emanating from driver's door or mirror?
    By HHGTTG in forum Golf MK6 - 2009 - 2013
    Last Post: 05-05-2011, 04:00 PM
  3. Wind Noise from rear door ??
    By simfin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-12-2010, 08:03 PM
  4. Question mk5 Golf wind noise - drivers side
    By petesaysblimey in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2009, 09:26 AM
  5. Golf MK5 Door wind noise and rattles
    By tony444 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2007, 03:28 PM
