Thread: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
  1. below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Mar 2012
    birmingham
    i have just had the engine management light come up on my a4 2.4 v6 petrol .when i plug the obd its says irregular warm up on bank 1 below effiecency what would that be
  2. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Feb 2012
    Glasgow
    Could be a 02 sensor or maybe a vaccum leak, I had a fault 0171 bank 1 too lean and it turned out to be a vaccum leak, I did think it was 02 sensor at first
  3. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Mar 2012
    birmingham
    is there a way of checking if its the catalyst or if its the lambda sensor
  4. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Feb 2012
    Glasgow
    You can look at the sensor and see if it's clean and still looking ok, I've been told there pretty sensitive tho. Mines were around about the 1 0 clock position in the engine bay,just in front of the battery
  5. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Mar 2012
    birmingham
    The code that came up is p0421 and p0431 which is both sides of the engine saying, warm up catalyst below efficeincy .So is it the catalyst that need replacing .ive checked the 02 sensor by a multimeter and it read 13 apparently under 20 its ok
  6. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Feb 2012
    Glasgow
    I'm not 100% but I reckon your cat will be fine, I think you get a sensor before cat and after cat... Maybe one of them
    There's normally guys on here that are excellent at diagnosing faults if you've got the codes
  7. Re: below effiecency on bank1 on my obd reader what would that be 2.4 v6 petrol
    Mar 2012
    birmingham
    yea the code is p0421 and p0431
  1. Question I need to replace my cats on my 2.4, how do I tell if I need OBD or non-OBD?
    By Carpie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2011, 09:39 PM
  2. Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    By boraking699 in forum Bora - 1998 - 2005
    Last Post: 01-07-2009, 03:57 PM
  3. Year 2000 Mark 4 1.4 Petrol OBD plug
    By ilfdlab in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2008, 03:01 PM
  4. Lambda Sensor (Bank1)
    By bbability in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-04-2008, 10:55 PM
  5. Petrol 2 Stroke Mix in Petrol Engine
    By gcmozart in forum Chat - Anything with wheels
    Last Post: 17-11-2007, 11:13 PM
