Thread: A4 2002 Brake Pad Warning Light (0)
Results 1 to 8 of 8
  1. A4 2002 Brake Pad Warning Light (0)
    Nov 2006
    Hi there, can anyone help. The brake pad level warning light has come on on my 2002 A4. We've changed the front pads, how do i reset the light? It looks like (0), the ABS sign is not on it nor is the brake fluid level, just the (o), any ideas?????
    PS......... is this the warning light on the DIS (Driver Information Display) rather than a light in the cluster...
    RickT
  2. Re: A4 2002 Brake Pad Warning Light (0)
    Dec 2006
    yes... theres 2 types of pads you can buy... ones with the sensors and ones without..
    The pads have a plug which plugs in behind the calpier.. if you have replaced with pads with sensors.. normally what happens is when you set off the warning light stay on and ABS light until you have braked as the sensors get confussed..
    I would suggest checking the pads to make sure the wires have a good connection... if they have.. its a faulty set of wiring on the pads..
    RickT
  3. Re: A4 2002 Brake Pad Warning Light (0)
    Nov 2006
    Rick, you are a star, thank god for this forum, what would i do with out it. You are a sweety!
  4. Re: A4 2002 Brake Pad Warning Light (0)
    Dec 2006
    Quote Originally Posted by mandilou View Post
    Which pads are they then... did you get some without the wire and plug??
    or are you going to go check the wiring to make sure you have a good connection..
    let us know how you get on..
    RickT
  5. Re: A4 2002 Brake Pad Warning Light (0)
    Jul 2007
    i've also come up with the warning. If you simply dis-connect the plug, will the warning come off? I haven't changed the pads, on initial inspection, the pads look fine. Also, what is the correct brake fluid levels? I can't really see anything because of the stupid cover!
  6. Re: A4 2002 Brake Pad Warning Light (0)
    Aug 2007
    Quote Originally Posted by SquashMan View Post
    Has the light just come on for you without you changing anything on the car?
    I had a similar problem a while back:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=27410
    Hope this helps!
  7. Re: A4 2002 Brake Pad Warning Light (0)
    Jul 2007
    thanks for the reply Hagis.
    My problem doesn't really to be as severe. It's just a simple warning. No ABS or TC warning light (and mine is a petrol so glow plug warning is n/a).
    can anybody else confirm whether unplugging the brake sensor would take the warning light off?
    TIA
  8. Re: A4 2002 Brake Pad Warning Light (0)
    Jul 2007
    just a thought, and can anybody confirm this.
    I got a letter from Audi saying that my brake fluid is due for replacing. Is it coincidental that the light has come on? or does this not effect it?
    TIA
  1. 2002 VW Polo Exhaust Emissions Warning Light
    By Lilly in forum Polo - Derby - Lupo - Fox
    Last Post: 20-12-2009, 01:11 AM
  2. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  3. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
  4. Emissions warning light Passat 2.0 SE 2002
    By Dannyboy in forum Archive posts
    Last Post: 11-02-2007, 06:11 PM
  5. Brake Pad warning light?
    By les in forum Passat - Archive Topics
    Last Post: 27-11-2006, 09:51 PM
