Thread: Rumbling/Drumming noise from the rear (of the car)...
Results 1 to 10 of 16
  1. Rumbling/Drumming noise from the rear (of the car)...
    Feb 2007
    North Yorkshire
    It's been a long time..!
    Question: I'm sure I can hear a slight drumming or rumbling noise from one of the rear wheels when I reach about 60/70 mph.... I wouldn't say it's that obvious, but I have a tendency to notice things like this I and I wondered if A4 Avant's were prone to noisy wheel bearing, or similar...
    Does anyone have a similar experience on a 33k miler Avant..? Is it common, or a known fault, etc...?
    Mark
    2010 Audi A4 Avant 2.0 TDI 143PS S-Line Special Edition | Misano Red | B&O | DAB | AMI
    May 2007
    knee deep in clunge
    14 Post(s)
    Check the inner edge of the tyres for saw tooth wear
    This normally occurs between 50 to 60 mph and sounds like a bearing
    Front bearings are common on 8k platform a4 but not the rear
    Normally the tyres on the rear
    Sent from my iPhone using
    My fat fingers
  3. Re: Rumbling/Drumming noise from the rear (of the car)...
    Feb 2007
    North Yorkshire
    Thanks a8 tech.... I'll check the tyres tomorrow... They're actually the originals which have done OK I suppose with +33k miles on them.
    If it is the tyres, that will be £460 for the a pair..........! Don't you just love buying tyres for Audi's...?!!!
  4. Re: Rumbling/Drumming noise from the rear (of the car)...
    Jun 2011
    fife scotland
    can be twisted tyre check round tyre with hands
  5. Re: Rumbling/Drumming noise from the rear (of the car)...
    Aug 2009
    Scotland
    It'll be the tyres I suspect. I had a similar experience prior to changing the rears on mine at about 35K.
  6. Re: Rumbling/Drumming noise from the rear (of the car)...
    Oct 2009
    Malvern
    I've had the exact same problem with my front and rear tryes, I was getting this awful noise even at low speeds sounded like I was driving a landrover with knobby tryes on, I took it to Audi thinking it was the wheel bearings going, the technician got my car lifted off the ground and said I think you need to look at this sir? He span one of the front wheel round by hand and it wasn't just a saw tooth wear on the tread the tyre wasn't ever round anymore?? it was covered with what looked like flat spots all around the tyres on all 4!!! he said I really needed to change them all, the car has done 27,000, but I said I could only afford to do two at a time @ £260 a corner, the rears still had 4-5mm tread on, the fronts were down to 1.5 -2.5mm so need changing anyway. So I got Audi to fit two new AO (Audi Only)ones to front with 8mm tread, I left the rears on for another time. The noise has gone now! But I still can't explain how they got in this state? The only thing I can think of is that this car had stood for 6 months not going anywhere? I think it was a show room car, I purchased it 6 months old with just 60 miles on the clock, now whether it just being stood in the show room for 6 months and moved around occasionally had put flat spots on the tyres from new, and the problem only then came to light once I had worn away the rubber? Want do people think? I hope there's not an underlying defect with the transmission that has caused this to happen to the tyres?, it is a Quatro all wheel drive system.
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
  7. Re: Rumbling/Drumming noise from the rear (of the car)...
    Feb 2007
    North Yorkshire
    Pauls898 - Thanks for the detailed reply.
    Interestingly my car was stood in the showroom for 3 or 4 months before I bought it, but I'd like to think that this isn't the cause for the tyre wear issues.
    I replaced my fronts at 27k miles, and they appear to be wearing OK, but the backs are now getting towards the end of their life (~34k miles), so I guess they are the cause of the increased road noise. Well I hope so anyway.
    Just for reference, I bought 2 Dunlop SP Sport MAXX GT (AO) - 255 35 Z R19 96 Y from Audi York for £455 (all in, inc VAT), after pushing them to match the best on-line price. Initially they wanted to charge me £500 + VAT, so it just goes to show that you can drive a deal if you're cheeky. Being a Yorkshireman helps in these situations..!!
    I'll get the rubber changed, and re-post an update when completed.
    YorkieMark
  8. Re: Rumbling/Drumming noise from the rear (of the car)...
    Feb 2007
    North Yorkshire
    UPDATE..!
    I've just had the rear tyres checked, and as per the feedback already received, the tyres have worn quite bizarrely on the inner edge, where there's some pretty obvious 'flats'...!
    I simply can not work out why tyres would wear in this fashion, and the only reason I can think why this would occur is possibly due to the wheel not running exactly true, perhaps a little bit like a bicycle wheel that's slightly buckled. I'll do a bit of research, but if anyone can offer an explanation as to why the tyres wear with flats, I'd be interested to hear more..!!!
    50pShapedTyresMark
    May 2007
    knee deep in clunge
    14 Post(s)
    In short
    Pronounced saw tooth wear occurs
    When toe in values are to high
    When tyre pressures are incorrect
    When the tread is course or open
    On tyres which are fitted to none driven wheels
    When the vehicle is driven very fast around tight corners
    My fat fingers
  10. Re: Rumbling/Drumming noise from the rear (of the car)...
    Sep 2008
    Berkshire
    Quote Originally Posted by Pimped-Passat View Post
    UPDATE..!
    My 143 has a worn N/S/R outer edge only with no flat spots. Audi Camberley wouldn't look into it without replacement tyres being fitted first (which I did question the logic as I wanted them to "see" the symptom, especially after their engineer's "blindness" to my juddering clutch woes). Laser tracking was done and very small adjustments made a month or two back.
    Anyway, a quick inspection didn't suggest anything was wrong to them. They simply recommended getting another laser tracking - but after the new tyres are fitted this time, not before. Maybe that is significant enough?
    A5 (Cabriolet) 2.0 TDI 177PS S-Line - Scuba blue, Technology pack (high), B&O soundsystem, Bluetooth (low), Heated seats, Autoglym life shine.
  1. Question Rumbling noise.............
    By Slim1174 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-10-2009, 10:06 AM
  2. Please Help Rumbling road noise at speed from rear
    By VWS in forum Bora - 1998 - 2005
    Last Post: 05-06-2009, 12:25 PM
  3. Please Help Rumbling Noise
    By saj26 in forum Chat - Anything with wheels
    Last Post: 04-10-2008, 11:50 PM
  4. Replies: 7
    Last Post: 17-02-2007, 02:24 PM
  5. A4 2.8 Rumbling noise
    By markcass in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 04:54 AM
