Thread: Added Fiscon Basic Plus, can't code into RCD510
Results 1 to 10 of 20
  1. Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    Hi all,
    I have an RCD510DAB (from a mk6 I think) in my Octavia and have just had a Fiscon Basic Plus fitted. I've gone to do the coding and ticked 77 for Telephone Prep in the CAN Gateway installation list, but when I try and select Telephone (CAN) in the Long Coding helper under the Radio Module (56), I get error 31 - "Coding Rejected: Error 31: Request out of range".
    Is there any way around this? The phone is paired to the car, I can make and receive calls and view information on the Maxidot display but I can't do anything through the headunit. Is there anything I need to do? When I fitted the headunit, I tried to select either VW Soundsystem or Skoda Soundsystem installed in Long Coding but they were both rejected with Error 31. Dana at Ross Tech seems to think this is normal and "No Sound System Installed" should be the option selected as the others are apparently specific to built in amps, Dynaudio, or other things like that.
    Any ides? I would be very grateful for your assistance.
    Ta
    J
  2. Re: Added Fiscon Basic Plus, can't code into RCD510
    May 2007
    knee deep in clunge
    14 Post(s)
    error 31 means not installed so ignore it
    post pictures please
  3. Re: Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    Would you like pics/screenshots/scans of what VCDS is reporting?
  4. Re: Added Fiscon Basic Plus, can't code into RCD510
    May 2007
    knee deep in clunge
    14 Post(s)
    yes and code changes please https://docs.google.com/viewer?url=h...scon_vw_en.pdf
    have you changed the code in 56/37 to tell the head unit it has can phone prep
    Coding
    Radio Configuration
    AUX-IN Access restricted
    CD-Changer/iPod/USB Connection Monitoring active
    AUX-IN Connection Monitoring activc
    Parking Aid installed
    Shortpress Steering Wheel Buttons installed
    Telephone OR Telephone Preparation (CAN) installed
    Back-Up Camera installed
    Sound System Correction
    Sound System not installed
    Volkswagen Sound System (DDP DSP)
    Skoda Soundsystem (CAN DSP)
    Dynaudio Sound System (DDP DSP)
    Volkswagen Sound System (BAP DSP)
    Dynaudio Sound System (BAP DSP)
    Speaker Channels
    Sound System (active Speakers)
    2 Speaker Channels (2 passive Front Speakers)
    4 Speaker Channels (2 passive Speakers each Front and Rear)
    Treble Speaker Monitoring
    Treble Speaker Monitoring deactivated (Sound System)
    Treble Speaker Monitoring for Front Speakers active
    Treble Speaker Monitoring for Rear Speakers active
    Treble Speaker Monitoring for Front & Rear Speakers active
    Vehicle Specific Frequency Response
    Linear Frequency Response
    Model specific Frequency Response
  5. Re: Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    I've read through the manual and only found reference to the code change in Address 19 (CAN Gateway), which I selected 77 for telephone prep.
    This is the most recent scan, I've omitted everything bar CAN Gateway, Radio and Telephone as I am not sure that it is relevant, but if you would like more please ask.
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    Revision: H37 Serial number: 250511F1000974
    Coding: 351303
    Shop #: WSC 12345 123 12345
    VCID: 30653F486338729
    No fault code found.
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L1548569
    Coding: 03000400040105
    VCID: 2C5D2B384F10169
    3 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 102999 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:58:52
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 102999 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:58:52
    02877 - Digital Radio Antenna (R183)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 102999 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:58:52
    Address 77: Telephone Labels: None
    Part No SW: KTC 364 95B HW: KTC 364 95B
    Component: SWP:3.23.5 H24 0210
    Revision: 00000000 Serial number: 00000000000000
    Shop #: WSC 21977 142 74100
    VCID: 2F673C34BE066D1
    The three fault codes on the Radio (Address 56) are down to the aerial currently having no 12V power.
    I have attempted to make the coding changes on address 56
    to: 03000402040105 - New
    Changing byte 3, Bit 1 to tick the check box marked Telephone OR Telephone Preparation (CAN) installed.
    When I try and save this, I get error 31.
    Am I doing something wrong?
  6. Re: Added Fiscon Basic Plus, can't code into RCD510
    May 2007
    knee deep in clunge
    14 Post(s)
    Well John its either the fiscon loom is incorrect or the unit is incorrect as once the gateway can see the phone then the radio only needs to be told to allow the function
    Out of intrest disconnect both the radio and the fiscon and see if a hard reset works
    Failing that send a ticket fiscon and check the fiscon firmware is the latest
    if you can screen dump vcds long code helper for address 56 as well as I dont have all the byte functions
  7. Re: Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    Sorry I didn't see you had added to your post before I posted up the scan results.
    Quote Originally Posted by a8 tech View Post
    I've tried and that's when VCDS gives me error 31.
    Coding
    Radio Configuration
    AUX-IN Access restricted - Bit 0 ticked
    CD-Changer/iPod/USB Connection Monitoring active - Bit 1 ticked
    AUX-IN Connection Monitoring activc - Bit 2 not ticked
    Parking Aid installed - Bit 3 not ticked
    Shortpress Steering Wheel Buttons installed - Bit 0 not ticked (I only have wiper stalk controls)
    Telephone OR Telephone Preparation (CAN) installed - Bit 1 not ticked
    Back-Up Camera installed - Bit 6 not ticked
    Speaker Channels
    Vehicle Specific Frequency Response - 01 selected Skoda Octavia (1Z)
    I've highlighted in bold everything that is selected on my car.
    I brought the 00 Soundsystem Non Installed to Ross-Tech's attention after it was fitted but they seemed to think this is normal.
    Not sure what else to do.
    Skoda Soundsystem CAN DSP is what I would like to use as I understand my car is CAN rather than BAP. I don't know if the headunit is having a wobbler because it's out of a later car and thinks it should be connected to a BAP system. Or am I making that up?
  8. Re: Added Fiscon Basic Plus, can't code into RCD510
    May 2007
    knee deep in clunge
    14 Post(s)
    Is the radio a retro fit?
    I would contact fiscon to check the compatibility against the radio hw and sw version
    Can you reset the radio as most code changes need the unit to be reset to take affect
    Without the exact details its harder but does vcds see the dsp amp in the installation list (it should not matter as this issue is just the radio display and radio menu not showing phone operations
    tick phone prep can and reboot the radio
  9. Re: Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    Yes it's a retro fit and had been previously fitted to another car. When I put it into my car it had retained its memory (presets, etc) so I guess it's never had a full reset. I am not sure if the unit has the option to be reset, but I guess pulling the fuse would have the same effect?
    Looking at Kufatec's site, I can't tell if the software version of my kit is the most up to date - the kit SW is something like (and I'll check and confirm) 3.23.5 but there is a version 3.247 on the Fiscon site for hardware version II (which I am pretty sure I have). I don't want to go bricking either the HU or the kit, so might try resetting the HU first.
  10. Re: Added Fiscon Basic Plus, can't code into RCD510
    Apr 2012
    Leics
    Can't see a way of doing a reboot on the radio other than pulling the fuse (or disconnecting the radio and then pulling the fuse).
    Despite being taken from one car and fitted to mine (and briefly fitting to my dad's as a fault finding exercise) all the presets and info were stored so although a full reset must be possible, I've no idea how to do it!
  1. Questions about FISCON in new Polo with RCD510
    By Gorm in forum In Car Entertainment
    Last Post: 17-05-2010, 08:22 PM
  2. Please Help Fiscon Basic Plus kit
    By sam_77uk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2009, 01:01 PM
  3. Added Fiscon Pro to RCD 510
    By anand81uk in forum Golf MK6 - 2009 - 2013
    Last Post: 11-09-2009, 10:24 AM
  4. Coding for FISCON BT Basic in New TT J8
    By robhills in forum In Car Entertainment
    Last Post: 23-08-2009, 07:21 PM
