Thread: 2.6 ABC stalling
  1. 2.6 ABC stalling
    Nov 2008
    My 2.6 coupe has starting stalling when dipping the clutch at very low speeds. It even causes the steering lock to come on meaning if i'm parking I almost hit random objects.
    Recently I've changed one manky looking lambda sensor, would the other one be causing problems too? Also i've read that it maybe a vacuum leak, where would the hose(s) be?
  2. Re: 2.6 ABC stalling
    131 Post(s)
    1978 Post(s)
    The idle valves are prone to failure BUT the ABC engine is very difficult to set up for a good idle and you need full VCDS and the set up info.
  1. Abc map
    By 95cabrio in forum 80 - 90
    Last Post: 23-03-2012, 07:47 PM
  2. Over heating ABC V6.......WHY?
    By fourringsrus in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-11-2011, 09:20 PM
  3. ABC V6 Cat, please help
    Last Post: 16-05-2011, 10:21 PM
  4. ABC v6 fuel pipework
    Last Post: 13-04-2011, 08:31 PM
  5. Audi 80 2.6E V6 1993 ABC
    By STEPHEN LYTTLE in forum 80 - 90
    Last Post: 06-09-2007, 01:48 PM
