Thread: Engine idle speed
  1. Engine idle speed
    Dec 2006
    Maidstone, Kent.
    Hi.
    bit of a basic question, but is it possible to adjust the idle speed of my engine with VCDS?
    I have a 2004 130 4Motion Passat on which the idle seems high, in fact it is certainly higher than my previous 2WD 130. Only by around 200 rpm, but is enough to notice the difference, and in fact the previous one was more pleasant at idle with the lower rpm.
  2. Re: Engine idle speed
    Apr 2009
    Anything between 800 and 925 is considered normal, if its much higher, its usually an
    indication that an engine sensor is supplying false information to the ECU, start with
    the coolant temp sensor.
    Regards
    Jim
    Still Crazy After All These Gears
  3. Re: Engine idle speed
    134 Post(s)
    2005 Post(s)
    Some are adjustable and full VCDS will provide the info.
  1. AUDI A4 1.9 tdi AWX engine - what is your idle speed?
    By sabikeuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-10-2010, 10:41 AM
  2. AEE engine idle speed adaptation
    By ianhayter in forum VCDS - General Questions
    Last Post: 26-03-2009, 02:41 PM
  3. Question Engine Idle speed sticks 1100rpm sometimes
    By madbonky in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2009, 06:26 PM
  4. GTI Engine idle speed.
    By dky_00 in forum Golf MK5 - 2004 - 2009
    Last Post: 25-08-2008, 12:33 PM
  5. 1997 Polo 1.9 SDI Erratic Idle Engine Speed
    By wkhattak in forum Polo - Derby - Lupo - Fox
    Last Post: 10-08-2008, 05:17 PM
