Thread: Xenon control unit
Results 1 to 8 of 8
  1. Xenon control unit
    Feb 2011
    carnoustie uk
    hi anyone know where i can get a Xenon control(ballast) bosch part number 1 307 329 114.
    i've had 2 from HIDS direct but the last 3 digits were different and they threw up a fault for the adaptive lights. the part is £342 + vat from audi so still searching to see if i can get it cheaper.
    Paul
  2. Re: Xenon control unit
    134 Post(s)
    2019 Post(s)
    I did not think you could get the ballast genuine. What is the Audi part number? Is that the full and correct Bosch part number?
  3. Re: Xenon control unit
    Feb 2011
    carnoustie uk
    the audi part number is 8EO941329 and 1 307 329 114 is the the bosch number printed on it. all bosch ballasts seem to have very similiar numbers just usually the last three digits that are different
  4. Re: Xenon control unit
    134 Post(s)
    2019 Post(s)
    I am pretty sure the J343/J344 gas discharge light control units do not contain the ballast, I went through this with a TT not long ago. I have a spare one of these units at work (brand new in the box) to illustrate this! On the TT I had to fit a new headlight tio cure the problem with the light not coming on.
  5. Re: Xenon control unit
    Feb 2011
    carnoustie uk
    the control unit i need is screwed to the underside of the headlamp with 3 screws and has 2 electrical sockets in it. does the one you own have the same serial numbers as i'm looking for?
  6. Re: Xenon control unit
    134 Post(s)
    2019 Post(s)
    I found both the used and brand new units today and the brand new genuine VAG TPS supplied unit has absolutely no VAG ID on it at all and is made in France by AL (Automotive Lighting) who supply a lot of lights to VAG. I need to look into the parts a little deeper so I will dig out the invoice as I have lost the box it came in.
  7. Re: Xenon control unit
    134 Post(s)
    2019 Post(s)
    Quote Originally Posted by paulperrie View Post
    This is an AL number, not Bosch.
    The unit we have is a VAG 4D0 907 476 B which is an AL 1 307 329 066.
    The number you want, 8E0 941 329, changed to 8E0 907 391 C and then to 8P0 907 391 so unfortunately the one we have is not correct, sorry.
  8. Re: Xenon control unit
    Feb 2011
    carnoustie uk
    thanks for checking
    Paul
  1. Xenon control units/ballast
    By Heathy in forum Chat - Anything with wheels
    Last Post: 09-09-2010, 12:39 AM
  2. Control Unit
    By joannelut in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2010, 10:28 PM
  3. Xenon Range - Internal Control Module Memory
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 12:42 PM
  4. Xenon retro-fit: what is a control unit?
    By Akash in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-07-2008, 11:11 PM
  5. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
