Thread: Vac system
Results 1 to 10 of 13
  1. Vac system
    Oct 2007
    The brake pedal is going down quite fast with the engine running, is there a circuit diagram for the vac system or a step by step guide for finding the leak/pump problem and what should the vac reading be at x RMP?
  2. Re: Vac system
    Mar 2009
    HERE from martin1810s website. (Thank you Martin, lots of excellent info on it)
    I came in to this world with nothing and I've still got most of it left.
  3. Re: Vac system
    Jun 2007
    Gwent
    Sorry I don't know the vac figures, but think the fault may be on the hydraulic circuits? Surely a vac leak would make the pedal harder? e.g. I recently had a rear caliper apart due to sticking handbrake. I bled the caliper with engine off and had same symptoms you have. I then bled again with engine running and the fault cleared. Trapped air must have caused it, but could see a master cyl problem or leak giving similar symptoms?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: Vac system
    Oct 2007
    I have never heard of bleeding the brakes with the engine running, it should be done with it off so no servo assistance is available.
  5. Re: Vac system
    Jun 2007
    Gwent
    I read somewhere that ABS sometimes causes it to be difficult to bleed rears with the engine off, running the engine is said to help. I had trouble bleeding a rear caliper so tried again with the engine running I was succesful 2nd time. Maybe luck, maybe something in it - who knows?
  6. Re: Vac system
    Oct 2007
    Quote Originally Posted by scotty33 View Post
    I do think you are on the button, I had stripped the rears and have now checked the vac system and the servo, no problems but still the sinking pedal. I do have a very small amount of soft travel without the engine running, I will give your advice a try, thanks a lot
  7. Re: Vac system
    Oct 2007
    Quote Originally Posted by caldirun View Post
    Today I bled the brakes with the engine running, still the same problem, my vacuum system checks out fine, no leaks and loads of depression which holds when I press the brake pedal with the engine running. Is this symptomatic of a failing brake servo?
  8. Re: Vac system
    Jun 2007
    Gwent
    Sorry, I can't see how it would be servo issue? lack of assist or unwanted assist, yes servo, but soft pedal, for me, must be hydraulics? Is it possible the fronts need bleeding?
  9. Re: Vac system
    Oct 2007
    I bled all four callipers yesterday. The brakes are perfect without the engine running, press on pedal it moves very slightly then is solid and holds that position, now start the engine, the pedal descends going to the floor in approx 12 seconds. The only change is the servo assistance comes in.
  10. Re: Vac system
    Pembrokeshire
    22 Post(s)
    without the servo you are not compressing the air, which you do easily with the help of the servo. are there bleed screws on the master cylinder itslef. if there are try bleeding these as well.
  1. Vac hoses - part codes
    By murphy21082 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-01-2012, 06:52 PM
  2. Question VAC Pipe Sizes
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2011, 11:17 PM
  3. Question VAC Pipes
    Last Post: 28-02-2011, 06:06 PM
  4. Vac pump
    By way318 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2011, 05:52 PM
  5. Vac Pipe to Brake Servo
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:07 AM
