Thread: Water ingress woes, below battery filling up then emptying.
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Water ingress woes, below battery filling up then emptying.
    132 Post(s)
    1979 Post(s)
    The trouble is, Audi say remove the valves but I strongly disagree with this, it is a panic measure they did not think through properly and I think the whole process was a cynical ploy to get owners back into the Audi system, just like the Beastie Boys badge freebie that VW did in the 80's, new badges but we get ALL your vital statistics.
  2. Re: Water ingress woes, below battery filling up then emptying.
    May 2010
    Tregarth UK
    Ah, it was the windscreen, as I suspected, but also the drains were partially blocked too. Oh and it was National Windscreens, not Autoglass, they did it in September 2010, so not much chance of getting it sorted by them, silicone for now, hopefully chipped later.
    Thanks for your help.
    Kieran
    VW Passat Estate SE 1.9pd Tdi (130 AWX) 2002 162k
  3. Re: Water ingress woes, below battery filling up then emptying.
    Gwent
    Quote Originally Posted by KieranM View Post
    Kieran
    Try quoting the sale of goods act at them? Goods and services need to be fit for purpose - this job clearly was not...
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: Water ingress woes, below battery filling up then emptying.
    May 2010
    Tregarth UK
    Yeah I'll give that a go.
  5. Re: Water ingress woes, below battery filling up then emptying.
    May 2010
    Tregarth UK
    As an update, I put some washing up liquid around the passenger side windscreen column, and then cover with water, I initially was looking for bubbles, saw a couple but not that many, just one or two. I then ran a hose over the windscreen.
    Funnily enough I now have soapy water seeping out of the material of the passenger side windscreen column near the top, where on closer inspection is a bit of a messy job. National windscreens (closest branch is in Oswestry), said they were doubtful it was the windscreen, but if it is, then the windscreen will be replaced under warranty.
    Thanks for your help, here's hoping when they look at it they come to the same conclusion that I and the garage have.
  6. Re: Water ingress woes, below battery filling up then emptying.
    May 2010
    Tregarth UK
    Windscreen replaced today free of charge, here's hoping this sorts it, and none of the other various places it could leak from aren't!
    Thanks for the help as always.
  7. Re: Water ingress woes, below battery filling up then emptying.
    #17
    May 2010
    Tregarth UK
    It has been raining for a good while - no leaks
  8. Re: Water ingress woes, below battery filling up then emptying.
    #18
    Oct 2005
    Wettest drought ever huh
    Good news on the fix.
  9. Re: Water ingress woes, below battery filling up then emptying.
    #19
    132 Post(s)
    1979 Post(s)
    Makes me want to weep (sorry can't do that, waste of water), these overpaid muppets in charge of the water utilities start a country wide panic over water shortages then we have the wettest April in 112 years!
  1. 2003 A4 battery drain following water ingress
    By kezward in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2010, 08:30 PM
  2. Water filling in boot (with photo)
    By chrisgeary in forum Golf MK4 - 1999 - 2004
    Last Post: 13-12-2009, 04:33 PM
  3. Bulkhead filling with water
    By renedrag in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2009, 07:12 PM
  4. Golf filling up with rain water!
    By elsid in forum Golf MK4 - 1999 - 2004
    Last Post: 12-08-2008, 06:24 PM
  5. Question Audi A5 filling woes
    By perkman in forum New Member Introductions
    Last Post: 28-06-2008, 01:33 AM
