Thread: Vac system
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Vac system
    without the servo you are not compressing the air, which you do easily with the help of the servo. are there bleed screws on the master cylinder itslef. if there are try bleeding these as well.
    If there is air in the system you will feel a spongy pedal without servo assistance, if you release the pedal and press again it will still feel spongy, it will not sink all the way down under servo assistance and feel fine without.
  2. Re: Vac system
    Pembrokeshire
    22 Post(s)
    ok then, so do you have bleed screws on the master cylinder or not ?
  3. Re: Vac system
    Just found this post from last year (thanks Steviestdi)
    Re: Sinking brake pedal.
    Just to update, the fault is now sorted
    It required the abs unit bleed which is done diagnostically.
    Work carried out by a site sponsor Walsh motors.
    This I will try, I am sure I have read it can be done with Vagcom
  1. Vac hoses - part codes
    By murphy21082 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-01-2012, 06:52 PM
  2. Question VAC Pipe Sizes
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2011, 11:17 PM
  3. Question VAC Pipes
    Last Post: 28-02-2011, 06:06 PM
  4. Vac pump
    By way318 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2011, 05:52 PM
  5. Vac Pipe to Brake Servo
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:07 AM
