Thread: A4 2.0ltr TFSI Quattro S-Line
Results 11 to 20 of 21
  1. Re: A4 2.0ltr TFSI Quattro S-Line
    #11
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by quattrodlo View Post
    Do you have a part number for the replacement bulbs you bought?
    David
    No part number because I bought them from ebay.
    First set I bought cost £54 from Londoncolour. one bulb was damaged but a replacement was sent without hassle and then I was refunded postage when I returned the damaged bulb. Recommended seller but there are cheaper.
    Having broken a bulb in an attempt to fit it, I had to order more but this time I found a cheaper seller - bluechargedirect. Around £20 cheaper with quick delivery too.
    So it turns out I fitted one bulb from one seller and the other one from another seller.
    I think the OEM bulbs are 4300K and I ordered 6000K which from what I could gather was the best/optimum colour temperature. If you go too high, then the bulbs look more blue and emit less light. The 6000K bulbs when fitted, make the OEM ones look yellow!!
    It was awkward and tricky fitting them first time but now that I've done it, I could do it again quite easily. If you've never fitted them before then allow a couple of hours for both sides. Also check out the "how to" for a few tips to save any heartache (or walletache!)
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  2. Re: A4 2.0ltr TFSI Quattro S-Line
    #12
    Leicestershire
    Are these the right bulbs?
    http://www.ebay.co.uk/itm/2-Xenon-HI...ht_3894wt_1180
    H7 6000k ??
    Audi A4 2.0T FSI Quattro S Line 2005 - 262bhp - 330nm
    Adaptive Xenons - Alcantara Upholstery - Dvd Sat Nav - Heated Seats - Rear Airbags - Bose - Comfort Pack - Seat Memory - Bluetooth Dash Prep - Park Sensors - Cruise Control - Interior Light Pack - MFSSW - RS4 Arb - Rear Tints - RS4 Grill
  3. Re: A4 2.0ltr TFSI Quattro S-Line
    #13
    Aug 2009
    Near Lanark
    21 Post(s)
    David
    Yep, that's the right bulbs.
    But before you order, check out bluechargedirect as a seller.
    Same bulbs will be around £20 cheaper......something like £33.95 for the pair.....and that's actually what's in my car just now.
    EDIT - I've managed to get bluechargedirect mixed up with the bulbs....I bought an HDMI cable from them!!!
    Check this item http://www.ebay.co.uk/itm/2707117544...84.m1497.l2649 - it's hids-direct......£33.95 for the same bulbs. Currently in my car and working perfectly.
    So just ignore bluechargedirect, unless you're looking for HDMI cables!!!
  4. Re: A4 2.0ltr TFSI Quattro S-Line
    #14
    Leicestershire
    I did wonder.
    The link i sent you are just £9.99 for the set. Can this be right?
    Quote Originally Posted by darich View Post
  5. Re: A4 2.0ltr TFSI Quattro S-Line
    #15
    Aug 2009
    Near Lanark
    21 Post(s)
    I did wonder.
    Must be because I was logged into ebay....apologies!
    that's the right seller.....hids-direct. just check out their D1S bulbs with colour temp of 6000k and H7 fitment......they're £33.95 for a pair.
  6. Re: A4 2.0ltr TFSI Quattro S-Line
    #16
    Leicestershire
    Sorry im getting confused.
    Is there different variations of a H7 6000k bulb?
    Is D1S a different fitment to an H7 or can i but an D1S H7 6000k bulb?
  7. Re: A4 2.0ltr TFSI Quattro S-Line
    #17
    Aug 2009
    Near Lanark
    21 Post(s)
    God I'm having a bad night.....D1S is the fitment....Ignore the H7 part of it.....I'm thinking H7 because I'm upgrading the lights on my bike.
    D1S fitment
    6000k
    hids-direct
    £33.95
    hopefully that's sorted it out.
    EDIT - signed out of ebay...try this link http://www.ebay.co.uk/itm/D1S-factor...item3f07ad8f03
    should take you to the above bulbs.....hopefully
    apologies for the multiple confusion!!!
  8. Re: A4 2.0ltr TFSI Quattro S-Line
    #18
    Leicestershire
    Okay so i have replaced both bulbs and they look great, the 6000k is a much nicer slicker look. It only took around an hour in total.
    However i still have the "Right Front Main Beam" warning light on.
    Does this light need to be put out somehow or should it have gone out on its own?
    Any advise is appreciated.
    David.
  9. Re: A4 2.0ltr TFSI Quattro S-Line
    #19
    Aug 2009
    Near Lanark
    21 Post(s)
    Strange......
    my warning came on once when mine were flickering. I switched off and back on and that cleared it.
    When I replaced my bulbs I had no warnings at all....other than the ESP light coming on but from reading other posts I knew that was likely and that it would go out after a few metres driving.....it did.
    I didn't receive any bulb warning lights at all.
    I'd have expected it to go out on its own. Have you tried pressing the check button to make the car check all the circuits etc?
  10. Re: A4 2.0ltr TFSI Quattro S-Line
    #20
    Leicestershire
    Well this just sucks !!!
    My drivers side bulb in out again.
    I imagine my only option left is the ballasts. I got about a month motoring with a smile before my heart sank.
    I have adaptive xenons, does any one know the part numbers?
  1. Question A3 2.0 TFSI Quattro S-Line newbie questions
    By archwayanimal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-03-2012, 12:01 PM
  2. Attention 2007 2.0 tfsi S Line quattro must sell by Monday
    By Janus99 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-02-2010, 01:13 PM
  3. ADVICE PLEASE = 2.0 TDI(170) quattro or 2.0 TFSI quattro??
    By missscotia in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-01-2010, 11:15 PM
  4. What is my A3 worth...2007 2.0 TFSI Quattro S LINE
    Last Post: 22-09-2009, 07:04 PM
  5. A4 3.0ltr Quattro Issue
    By mpgscott in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-01-2009, 11:26 PM
