Thread: A4 1.9 TDi 130 AWX not getting upto temp
Results 1 to 10 of 15
  1. A4 1.9 TDi 130 AWX not getting upto temp
    May 2007
    Liverpool
    Just started using the car after buying last month. I gave it a full service the other week too. I did a 40 mile drive in it on Friday and notice the engine doesn't get upto 90 degrees. It sits at about a quarter. (45?)
    Could it be the sensor?
    1998 Audi A4 2.8 V6 quattro
  2. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Pembrokeshire
    22 Post(s)
    does the heater chuck out toasty hot air or lukewarm air ?
    May 2007
    Liverpool
    Ooh I don't know. Not needed to use the heater. What you thinking? Airlock?
  4. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Pembrokeshire
    22 Post(s)
    if it blows out lukewarm air then its probably your thermostat not closing. if it blows out really hot air then the stat is ok and it could be the sensor or gauge.
    my money is on lukewarm air and a failed stat. test drive it is then, good excuse to go for a quick blast. after 3 miles or so the heater should almost be capable of burning your skin off on full temp.
  5. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Apr 2012
    kent
    80% of the time, it'll be the thermostat rather than the sender. The thermostat failing on these cars is a really common problem, but very cheap and easy to fix. 20min job maximum.
  6. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Dec 2009
    southampton uk
    Always fit a genuine stat
  7. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Apr 2012
    kent
    Quote Originally Posted by mikeybutch View Post
    Well, the stats fitted to these cars are all suffering failure, so any other make is likely to be just as good. Anyway, it's not like Audi make the stats.
    May 2007
    Liverpool
    Think it must be that. The Missus said the heaters got warm on the drive to work but not hot! I'll take a trip to GSF this week and report back.
  9. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Mar 2007
    Lancashire
    Mine is like that but the sender is to blame. I got a new one and it seems to read the correct temp and fluctuates accordingly. I did a run with VCDS and it gets to about 85c even though the gauge shows 70c.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  10. Re: A4 1.9 TDi 130 AWX not getting upto temp
    Jul 2009
    warrington england
    Change the thermostat for what they cost. I have the same engine mine went the other month just make sure you put the right antifreeze in.
  1. vacuum hose diagram for a TDI 130 AWX
    By vwnige in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2012, 11:57 AM
  2. Please Help a4 awx 130 tdi avant: no power..no turbo?
    By TapMyHed in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-07-2011, 09:28 PM
  3. 130 pd awx coolant temp low
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2011, 10:43 PM
  4. please,where is 2001 130 tdi,awx engine fuel filter position?
    By ad777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-08-2010, 08:49 PM
  5. Wiring diagrams for passat tdi 130 awx 52reg
    By DOUGtdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2008, 02:24 PM
