Thread: ignition problem
  1. ignition problem
    Apr 2012
    ballymena
    I'm having a problem with the ignition switch on my car - a 97 a4 the key turns too far and you have to shift it back to get the gauges/electrical accessories (wipers, headlights, etc.) to function properly again.
    Oct 2010
    Here And There
    Stop shouting at us What is your question ?
  3. Re: ignition problem
    Apr 2012
    ballymena
    Hi, i knew i was gonna get that reply, i pasted it from another search someone else had ( some problem as me)
    whats the fix for this? the key seems to travel to far in the ignition and then u have to turn it back a little to make lights etc work.
  4. Re: ignition problem
    May 2008
    I had to replace my ignition switch a while back when the spring return action on the ignition key started to feel a bit odd. The replacement was about a tenner from GSF. On removal could see that the plastic casing which had gone brittle with age, had broken away around the end of the return spring. It's a straightforward enough job, requiring a fairly minute screwdriver (can't remember if flat or posi' - I think flat) to remove the actual switch once you have dug out some paint/potting compound from around the heads, and voila - problem solved!
  5. Re: ignition problem
    Apr 2012
    ballymena
    thanks il change the switch!
  1. Ignition problem?
    By atz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-06-2010, 11:38 PM
  2. ignition problem
    By a-teamlambretta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2010, 05:55 PM
  3. Ignition Problem
    By theprodigy in forum Golf MK3 - 1993 - 1999
    Last Post: 20-04-2009, 07:50 PM
  4. Question A4 Ignition Problem
    By RookieRab in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2009, 08:30 PM
  5. A3 ignition problem
    By olski1975 in forum Audi A3 - Archive Topics
    Last Post: 09-01-2008, 12:04 AM
