Thread: intermitent sqealing aux belt and high volts
  1. intermitent sqealing aux belt and high volts
    Jun 2008
    Hi, can anyone offer any advice please on a problem i have on my a6 c5 1.9tdi 2002 130bhp, my drive belt squeals on start up(most times)usually when cold, and have noticed recently my voltage gauge going up and down from 8 to almost 16, stays more at nearly 16 all the time. only had car few months and came with good service record, noticed alternator pulley was renewed about 18mths ago, timing belt was done 6mths ago and records state with all drive belts and tensioners(kit) replaced. is it possible some of these parts could be faulty again in such a short time. alternator pulley has done 15,000 miles since replaced or is the alternator itself the problem. not sure where to start with this, any advice, suggestions would be gratefully received. thanks billy g.
  2. Re: intermitent sqealing aux belt and high volts
    Pembrokeshire
    22 Post(s)
    your alternator is goosed. the max charge volts should be around 14.5 anything higher means the regulator isn't doing its job. you should not really use the car like this as you will probably also need a new battery as they dont like being overcharged.
  3. Re: intermitent sqealing aux belt and high volts
    Jun 2007
    This may be a seized spragg clutch in the alternator pulley. This is a one way free wheel device. However 16 volts is a problem then can destroy your battery so get it checked out. Regards Peter
  4. Re: intermitent sqealing aux belt and high volts
    Jun 2008
    hi, thanks for the replys, had a look under the bonnet while engine running and noticed when the squeeling noise started the pulley on the alternator was intermittedly stopping for a second in time with the noise. turned the steering left and right on full lock with no jumping on the tensioner or anywhere else, volts on volt meter on dash reading between 14 and 15 more 15, so am i sure to replace the alternator? my local alternator and starter motor garage has said they will replace mine with trading old one, supply and fit for £110, is that good? 12 months warrenty too.
  5. Re: intermitent sqealing aux belt and high volts
    Mar 2008
    High Wycombe
    Quote Originally Posted by billy g View Post
    Well, ECP list a new alternator for £175, so £110 fitted with a year's warranty sounds very good!
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: intermitent sqealing aux belt and high volts
    Apr 2012
    Devon, UK
    The alternator drive belt went on my 2004 1.9 TDi a few months ago; replace by local garage - not a specialist but a good guy nonetheless - but the volts ever since have been up towards the 16V area; was also a bit sluggish starting over the winter months but all fine now. Could there be a fault in the way it was fitted, or with the battery, or do you suspect the alternator - I would have thought that, if it was the alternator, it would have given up by now!
  7. Re: intermitent sqealing aux belt and high volts
    Jun 2007
    14.4 to 14.6 volts max when the battery is cold. Have you measured the voltage with a meter. 16V would cause the battery to overheat and use up the electrolyte. Best get it checked out. With the battery warm then 13.8 to 14 volts is normal. Regards Peter
  1. 2005 (55) A6 Avant intermitent high level brake light
    By Steve-T in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-03-2015, 12:30 AM
  2. Question Aux Belt Flapping
    By nellychat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-06-2010, 07:01 AM
  3. Please Help Q7 MMI High Aux in Problem
    By alsblade in forum In Car Entertainment
    Last Post: 26-04-2010, 03:29 PM
  4. Aux belt tensioner
    By James99 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2009, 12:20 AM
  5. 95' 80TDI intermitent high reving problem
    By Hannover H in forum 80 - 90
    Last Post: 13-01-2009, 09:39 AM
