Thread: Passat 2.0 2008 TDI CR timing marks
  1. Passat 2.0 2008 TDI CR timing marks
    Mar 2012
    essex
    Hi Can any help with my Passat 2.0 2008 TDI CR timing marks/pin locking locations
    Many Thanks
  2. Re: Passat 2.0 2008 TDI CR timing marks
    Norfolk
    They are fairly self evident once you set No1 to TDC. The crank lock is the same one used on previous engines. it will only fit the pin hole when in the right place. The cam shaft uses the usual cam pin, through the drive cog into a hole. You now need two of these pins. The other one fits in basically the same place but in the pump to lock that.
    So one crank lock key and two pins and nothing can move.
  3. Re: Passat 2.0 2008 TDI CR timing marks
    Mar 2012
    essex
    Hi Martin
    Thanks for the info ....Just a quick unrelated question I need to get a new air blower relay wich is relay 460 would I need to get this from VW or is there an after market equiverlent ?
  4. EHB problem
    Oops
  1. Question LT 28 2.5 timing marks
    By toger13 in forum The Commercial Range
    Last Post: 11-10-2011, 08:27 PM
  2. Please Help Passat TDI Timing marks???
    By Tonydiesel in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2010, 11:29 PM
  3. Timing Marks
    By Seanious in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-12-2008, 10:27 AM
  4. Audi a4 tdi 1997 timing marks
    By shuvit2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2008, 10:55 PM
