Thread: Please help my 1.9 tdi as am running out of ideas
Results 1 to 10 of 14
  1. Please help my 1.9 tdi as am running out of ideas
    Apr 2012
    newcastle
    Hi all newbie here,
    Having some problems with my A4 1.9 tdi, 1999, 189k
    When I try to start the car the Glow Plug Light only comes on the odd time after turning the key a good few times, if there's no light the car won't start and when the lights on it starts then after a few minutes it has a rough idle issue.
    Had the car scanned with Vag Com and it showed up these issues
    18062-Please check DTC Memory of instrument cluster
    P1654-35-10- - Intermittent
    17964-Charge Pressure Control
    P1556-35-00- Negative Deviation
    17552-Mass Air Flow Sensor (G70)
    P1144-35-10-Open or short to ground - intermittent
    18027-Glow Plug Relay (J52)
    P1619-35-10-Open or short to ground - intermittent
    So I replaced the Mass air flow sensor, Glow plug relay (Mine was relay number 219 not 109) and had the errors cleared. Then tried to start the car but still no glow plug light until a few turns of key then it would start and after a few minutes the rough idle was back again.
    Scanned car again and its now showing 1 issue:
    01314- Engine Control Module
    49-10- No Communication.
    Any help would be great as I really want to get this running.
  2. Re: Please help my 1.9 tdi as am running out of ideas
    Pembrokeshire
    22 Post(s)
    change the ecu relay, or pull the cover off and solder the dry joints up.
  3. Re: Please help my 1.9 tdi as am running out of ideas
    Apr 2012
    newcastle
    Hi Zollaf, Which relay is the one for the ecu ?
  4. Re: Please help my 1.9 tdi as am running out of ideas
    Pembrokeshire
    22 Post(s)
    whats your engine code ?
  5. Re: Please help my 1.9 tdi as am running out of ideas
    Apr 2012
    newcastle
    Engine code is AHU and its the 1999 face lift 90 BHP model
  6. Re: Please help my 1.9 tdi as am running out of ideas
    Pembrokeshire
    22 Post(s)
    i have no details on autodata for the facelift, but the previous version, its in the ecu box under the bonnet, front scuttle in front of the driver and is number 3.
  7. Re: Please help my 1.9 tdi as am running out of ideas
    Apr 2012
    newcastle
    Removed ecu cover and I'am faced with 3 relays, one closest the windscreen is 370 (grey) 53 (black) and 219 (black). So I'am guessing that number 3 is relay 370 (grey) as 219 has already been renewed.
    cheers
  8. Re: Please help my 1.9 tdi as am running out of ideas
    Pembrokeshire
    22 Post(s)
    not sure tbh, it should be the one on the right if they didn't change anything between yours and the earlier one. try taking the cover off and check for dry joints.
  9. Re: Please help my 1.9 tdi as am running out of ideas
    Apr 2012
    newcastle
    Do you mean the ecu cover? and what do you mean by dry joints?
    sorry for being the novice but my electrical skills aren't the best
  10. Re: Please help my 1.9 tdi as am running out of ideas
    Pembrokeshire
    22 Post(s)
    remove the cover from the actual relay, they should pop off if you use a screwdriver to gently prise the cover off, then look at the solder joints inside and look for circular crack.
  1. Please Help Any ideas for Engine fan constantly running?
    By warriorsage in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-12-2010, 11:09 AM
  2. car still not running right, out of ideas?
    By djackson 26 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-03-2010, 12:19 PM
  3. Please Help Lumpy Running - any ideas
    By Teflon in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-11-2009, 01:56 PM
  4. a3 1.9 tdi cutting out? any ideas!
    By darknight007 in forum Audi A3 - Archive Topics
    Last Post: 19-08-2008, 08:07 AM
  5. My Bug is just not running any ideas.
    By Mamba in forum The Classic VW's
    Last Post: 07-11-2007, 08:37 PM
