Thread: TDI Fuel Pump Failure and Replacement
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Question TDI Fuel Pump Failure and Replacement
    Jan 2011
    Leicester UK
    Driving a 2007 Passat Saloon 140 TDI.
    My engine decided to develop a fault accelarting away from an island and shut down 'Garage Engine Fault!' on the A43. Not a pleasant experience on the way home from a break but managed to get off on a slip road. The AA had a really good go at getting it going and narrowed it down to a shot fuel pump as the likely culprit (the sender in the tank, not the tandem) and hopefully not the injectors, no fault codes were showing. So home on the back of the truck watching all those other TDIs flying past.
    I've got a replacement (£130ish) and fitted it but now the car will turnover well but not catch (as though it is immobilised), a STOP! Oil pressure! warning appears on the dash after about 10 seconds of cranking (though the oil level is fine). There's plenty of fuel getting through to the filter now. I've already suffered the tandem fuel pump problem and had that replaced over a year ago, the car has been great since.
    This seems to have been a problem on earlier models, but I haven't seen much on problems starting after the replacement fuel pump. Anyone got any ideas?
  2. Re: TDI Fuel Pump Failure and Replacement
    135 Post(s)
    2029 Post(s)
    Has it had the injector recall done? Don't worry about the oil pressure warning under cranking, all modern VAG products do this under extended cranking.
  3. Re: TDI Fuel Pump Failure and Replacement
    Jan 2011
    Leicester UK
    No, there's no mention of the injector recall in the service history or docs.
  4. Re: TDI Fuel Pump Failure and Replacement
    Jul 2008
    Beverley, East Yorkshire
    I have a 2007 140 TDI (bought June last year with 59K and FVWSH) and rather than wait for the injector 'campaign' letter, I rang the VW main dealer (JCT 600) who booked the car in, supplied a courtesy car and replaced 3 injectors and the wiring loom all free of charge last week - really good service. The service receptionist told me that the injector problem was limited to 2008 models but VW were going back to 2005 models to check as goodwill - Ha Ha.
    Anyway, it might be worth ringing the dealer and getting your car in for a check - i was told that they remove the injectors, check the serial numbers and replace the faulty ones, the wiring loom is also replaced as a part of the recall.
    Regards
    Laurie
  5. Re: TDI Fuel Pump Failure and Replacement
    135 Post(s)
    2029 Post(s)
    Quote Originally Posted by pravens View Post
    Get on with it Tuesday morning! Call the local dealer and they will deal with it from there...
  6. Re: TDI Fuel Pump Failure and Replacement
    135 Post(s)
    2029 Post(s)
    Quote Originally Posted by Laurie2212 View Post
    yeh right! that's why there are so many for sale! The mechanic gets issued with the harness but it ends up in his tool box and then on fleaBay...
  7. Re: TDI Fuel Pump Failure and Replacement
    Jan 2011
    Leicester UK
    OK, thanks for the advice, I'll get onto VW and have the injectors sorted anyway, hopefully without argument. Are you saying that it's really an injector fault and the fuel pump is a red herring, wouldn't it show as an engine code fault? I still have the problem that the car is immobile following the fuel pump replacement, as though it needs resetting in some way, I'm going to try disconnecting and reconnecting the battery though that seems like a long shot.
  8. Re: TDI Fuel Pump Failure and Replacement
    Norfolk
    A code read will tell you instantly if the injectors are the fault.
  9. Re: TDI Fuel Pump Failure and Replacement
    Jan 2011
    Leicester UK
    Thanks for the help but not having much luck here, no fault codes showing on the injectors (though I will follow this up with VW). Fuel getting through but still just cranking; maybe a pressure thing but plenty seems to be coming through? Some kind of link between the pump and the immobiliser? It's driving me mad! (actually not driving me anywhere at all)
  10. Re: TDI Fuel Pump Failure and Replacement
    135 Post(s)
    2029 Post(s)
    The immobiliser being faulty would show itself by the engine starting and then stopping immediately so if it is not doing that, it is not the immobiliser as far as I can tell, plus you would get a fault code.
  1. fuel pump belt failure - 2.5 tdi
    By samie in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2012, 09:14 PM
  2. More Problems -- Fuel Pump Failure -
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2009, 09:01 PM
  3. A4 tdi fuel pump replacement
    By simyboye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2008, 05:03 PM
  4. fuel pump replacement ?
    By white.akita in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2008, 08:25 PM
  5. 2.5TDi fuel pump failure
    By Cool384 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-05-2007, 05:48 PM
