Thread: Fitting 1.0 Lupo alternator belt
  1. Fitting 1.0 Lupo alternator belt
    Jun 2011
    Gloucester
    Any guidance on correct way of fitting a new alternator belt tp my 1.0 petrol base model Lupo?
    The belt only runs around the crank pulley & the alternator. Old one off OK, but the alternator has a coil spring to maintain tension when tightening the belt.
    If I fit all bolts (loose) and try to push alternator back against the spring I can't get enough travel to allow belt to slip on. If I fit tensioner & belt I can't align the top mounting hole to allow last fixing bolt through, as belt & spring tension won't allow alignment.
    Checking forums and using common sense suggests only slackening all the bolts and swinging alternator enough to remove old / refit new, but without the special insertion tool mentioned on some threads I'm struggling on such a simple task!
    Any advice appreciated!
  2. Re: Fitting 1.0 Lupo alternator belt
    Apr 2009
    I've done it on a 1.4 Polo,so shall be similar i'd imagine. Where the tensioner is, it has (or the polo does anyway) a bolt on the side - not the moutnings bolts. Get a ratchet and pull it down towards you which in turn pushes the tensioner away from you. This allows you to get teh belt around all the wheels.
  1. Question Lupo/Arosa 1.0lL Alternator blet
    By Rawfy Coates in forum Polo - Derby - Lupo - Fox
    Last Post: 07-08-2011, 07:15 PM
  2. Replies: 2
    Last Post: 14-06-2011, 04:18 PM
  3. Question Correct fitting position of alternator belt on 1.9 td
    By Camp-freddy in forum The Commercial Range
    Last Post: 15-01-2010, 03:00 PM
  4. Passat fan belt alternator belt changing
    By flygrip in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-08-2009, 12:05 AM
  5. Kinda urgent - replacing belt tensioner, alternator pulley, and belt.
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
