Thread: V6 4motion with problems.
Results 1 to 10 of 10
  1. V6 4motion with problems.
    Apr 2012
    Northamptonshire
    Hey guys.
    Right where do I start.
    Well I bought a v6 4 motion 2001 xreg but I think it's got problems and big ones to
    The first problem is if it's left sat running it'll start overheating as fans are not kicking in and the water gets boiling hot.
    2nd problem my 4motion isn't working and the car will wheel spin on grass or wet road.
    Also the ESP switch in dash do t seem to work.
    My last problem is I think my dash/ speedo is screwed as some lights are missing when first switch ignition on...
    Any ideas cheers
    Dan
  2. Re: V6 4motion with problems.
    131 Post(s)
    1974 Post(s)
    The overheating problem is a common one, the fans have failed. If you look on top of the battery you will see the strip fuse has blown, replacing this may bring back the high fan speed but ultimately you will have to strip the front of the car down to fit two new fans and from VW these are about £325 for the pair although GSF do them for £170 the pair.
  3. Re: V6 4motion with problems.
    Apr 2012
    Northamptonshire
    I've had a look but the fuses in that black box seem to be fine.... Any other surgestions plz. All comments welcomed....
  4. Re: V6 4motion with problems.
    131 Post(s)
    1974 Post(s)
    Check closely, they crack. Fan failure is extremely common on these cars.
  5. Re: V6 4motion with problems.
    Apr 2012
    Northamptonshire
    I've sold it. Had stacks of problem got it to vw and they wanted 3000 nearly to fix it waste of 2700 in jan that was. Lost 1700 in 3..5 months
  6. Re: V6 4motion with problems.
    Apr 2012
    Northamptonshire
    That's 3000 not 300
  7. Re: V6 4motion with problems.
    131 Post(s)
    1974 Post(s)
    I don't know what they quoted you on so I cannot comment on the price (the fans cost about £600 to replace all in) but the thing that people tend to forget about the Golf 4 4M is it is not an ordinary Golf like the one I have just put a new 1.4 engine in for £3K, the G4 4M was a £24K car when it came out (plus options) and now it is an OLD £24K car and cars do not get cheaper to fix as they age, they get more expensive so what you had was an old expensive car (the used purchase price is irrelevant when looking at repairing a car) so they cost a lot to repair. For example a new engine in a box ready to fit is £3600 plus fitting which adds a bucket full of other parts required (budget for another £1K) and then four days labour to fit it. That means that a new engine in that car costs twice what it is worth.
  8. Re: V6 4motion with problems.
    Apr 2012
    Northamptonshire
    I'm no vw expert but here goes. I'm a Subaru man got 2. But vw Leicester told me it needed new water pump old ones bust. The fans needed replaced, the engine head gasket needed replaced also a temperature sensor, that was the overheating issue. Basicaly the car overheated to boiling point and blew the gasket..
    The 4wd system is trashed the rear diff has done some haldex thing inside plus the sensor needed replaced.
    The dash board needs replaced as its led not bulbs and there clearly gone wrong.
    And they also told me I need a new down pipe flexi has broken... So all this plus labour costs was why it totalled up. They wanted £85 ph labour...
  9. Re: V6 4motion with problems.
    131 Post(s)
    1974 Post(s)
    I can see the £3K now IF the head gasket had gone, which is rare.
  10. Re: V6 4motion with problems.
    Apr 2012
    Northamptonshire
    Was running for a good half hour stood still charging battery. But at this time I didn't no fans or water pump were screewed next door neighbour made me aware thought my car was on fire as inside had gone all steamy and steam bellowing out of under bonnet you'd of thought it was a kettle.. It was a slug anyway for a v6 tomany electrics think next time I'll get mk 2 convo....
  1. Please Help 2000 passat 2.8 v6 4motion rev counter and boot problems!
    By sondhi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-11-2010, 06:31 PM
  2. 4motion available only out of the UK?
    By discobarry in forum Golf MK6 - 2009 - 2013
    Last Post: 28-09-2009, 09:35 PM
  3. 4motion problems (leaks/damp, broken glovebox, ESP light)
    By Toiletduck in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2007, 05:06 PM
  4. Passat 2.8 4motion - Engine Problems
    By jackp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2007, 01:43 PM
  5. 4Motion
    By DeusLevitas in forum Bora - 1998 - 2005
    Last Post: 17-08-2007, 01:05 PM
