Thread: disc brake thickness on a3
  1. disc brake thickness on a3
    Apr 2012
    stockton on tees england
    what is the minimum thickness for discs on an a3.
  2. Re: disc brake thickness on a3
    Sep 2011
    Melksham, Wiltshire, UK
    Hi Audidav,
    According to Haynes manual:-
    FRONTS:-
    FS111 Disc - 280mm Dia, New = 22.0mm, Minimum thickness = 19.0mm
    FN3 Disc - 288mm or 312mm Dia, New = 25.0mm, Minimum thickness = 22.0mm
    REARS:-
    C1138 Disc - 286mm Dia, New = 12.0mm, Minimum thickness = 10.0mm
    C38 Disc - 255mm Dia, New = 10.0mm, Minimum thickness = 8.0mm
    Max. disc run-out across surface = 0.1mm
    Brake Pad lining minimum = 2.0mm
    Hope this helps?
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  1. Question Brake disc
    By nikefreekz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-07-2011, 04:11 PM
  2. Fabia vRS rear brake disk thickness
    By dervdog in forum Fabia
    Last Post: 18-07-2010, 06:37 PM
  3. Polo brake disc minimum thickness
    By polopolo in forum Polo - Derby - Lupo - Fox
    Last Post: 27-05-2010, 08:01 PM
  4. Polo brake disc minimum thickness
    Last Post: 21-04-2010, 09:45 AM
  5. Please Help Front brake disc min thickness T4
    By guzzler in forum The Commercial Range
    Last Post: 25-01-2009, 08:21 PM
