Thread: MK3 GTi Changing Discs - please help
  1. MK3 GTi Changing Discs - please help
    Hello
    I'm abit new to golfs and i've decided to change my front discs myself, however, I have taken off the wheel and caliper and can now not get the first disc off... do i have to take the Torx nut off the hub, as i thoguht the disc should just come off once all the correct bolts are off??
    Pleadse help.
    Cheers!
  2. Re: MK3 GTi Changing Discs - please help
    7 Post(s)
    Once the caliper is out the way and the small grub screw is removed it should just come off, however......
    Sometimes they rust onto the drive flange and will require a damned good belting with a hammer but....
    Be careful as with any hitting / belting, the impact stress will be absorbed by the wheel bearings, so....
    Hit the disk from the edge into the centre rather than from the back on the shiny bit. If it / they are stuck use the gently gently approach at first.
  1. front discs
    By mikeya4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2007, 10:33 AM
  2. Brake Discs
    By mwvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-07-2007, 01:33 PM
  3. Bigger discs = better brakes ?
    By jollybodger in forum Chat - Anything with wheels
    Last Post: 21-07-2007, 12:18 AM
  4. Discs - discolour
    By Mav2006 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 11:40 AM
  5. front discs
    By wilbur in forum 80 - 90
    Last Post: 10-01-2007, 10:39 PM
