Thread: Emptying wrong fuel from 1.9 tdi pd
  1. Emptying wrong fuel from 1.9 tdi pd
    Feb 2012
    Chester, Wales
    Hi Guys
    done the numpty trick of putting unleaded in my Passat 1.9 tdi!
    Got it towed home and got a mechanic albeit a Peugeot one coming round to do the work - got a pump and some empty tanks - where/how do we empty it?
    I have got a new fuel filter on order too.
    Put in 53 litres btw
  2. Re: Emptying wrong fuel from 1.9 tdi pd
    Feb 2012
    Chester, Wales
  3. Re: Emptying wrong fuel from 1.9 tdi pd
    Feb 2012
    Chester, Wales
    Need urgent help guys - got a mechanic mate round and the thing under the rear seats is not the fuel pump(as in the link from thread above) - a Duosensor ESP thing???
    Where is it located and how to access, please. BTW mine is an auto gearbox if that makes any difference?
  4. Re: Emptying wrong fuel from 1.9 tdi pd
    Norfolk
    If it was me and I had access to a pump, I would pull the feed off the tandem pump under the bonnet and suck the fuel out from there. The fuel pump is there in the tank. You can't be looking in the right spot. Look for some wires.
  5. Re: Emptying wrong fuel from 1.9 tdi pd
    Feb 2012
    Chester, Wales
    Thanks Martin
    we did end up draining the tank through the filler hole, then changed the fuel filter, put a 5 litres in through the filler hole and started up - bit of smoke at first, revved it up and let it tick over for 5 mins - going to fill it up now. Bodes well so far The thread I put up, said it was under the rear seats, which was for a 02 B5 Passat, so not sure why a 03 one is different, but mine is an automatic!?
  6. Re: Emptying wrong fuel from 1.9 tdi pd
    Norfolk
    I'm sure you will be fine. You can get away with quite a bit of petrol mixed in with diesel. The killer is neat petrol. It lacks the lubricating properties of diesel so pumps and injectors die quickly when fed neat petrol.
  1. Fuel pump issue now Fuel Gauge shows wrong amount
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2012, 05:53 PM
  2. Wrong fuel !!!
    By sugar9 in forum Chat - Anything with wheels
    Last Post: 08-09-2010, 11:44 AM
  3. Wrong fuel: Accidentally put £30 petrol in empty TDi Sharan
    By dmjbill in forum Touran - Sharan - Caravelle
    Last Post: 26-10-2009, 07:56 AM
  4. Wrong Fuel
    By paulncath in forum Chat - Completely Off Topic
    Last Post: 05-06-2008, 10:40 AM
  5. Emptying fuel tank on 2002 1.9 TDI
    By shortty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-12-2007, 10:23 AM
