Thread: High level brake light not working.
  1. High level brake light not working.
    Dec 2007
    Belfast
    Hi.
    Just noticed today that my high level brake light isn't working.
    Going to get the wiring checked tomorrow though I was thinking
    that it may not be wiring if the other two brake lights are fine ?
    Are there any other possibilities I should consider ?
    It will be getting looked at tomorrow so I would appreciate prompt
    feedback on this one folks.
    Thanks.
    Marko.
  2. Re: High level brake light not working.
    Southampton, UK.
    brake pedal switch perhaps?
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  3. Re: High level brake light not working.
    Dec 2007
    Belfast
    Cheers Herby.
    Will keep that in mind. Heading to the autospark shortly.
    Will update later.
  4. Re: High level brake light not working.
    Dec 2007
    Belfast
    Update on this post.
    It turned out to be a wire which had died.
    Got the initial problem, the brake light fixed but in the process
    damaged the rear jet feed join. Got that sorted with a piece of
    oxygen tubing and now she is good to go.
    Next is nearside front hub/bearing then coolant temp sender then
    petrol tank level indicator thing and possible offside front calliper then
    panel filter finished off with an oil and filter change !!
    Must go out the back to the money tree.
  1. Replies: 1
    Last Post: 09-09-2010, 04:36 PM
  2. High Level Brake Light
    By seftonbarn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2010, 02:19 PM
  3. golf gti high level brake light not working
    By kellya in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2010, 06:51 PM
  4. re: high level brake light
    By robins1uk in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 11:34 PM
  5. High Level Brake light
    By richard01276 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2007, 08:54 PM
