Thread: A8 3.0TDI Flashing glow plug light
  1. A8 3.0TDI Flashing glow plug light
    Mar 2010
    Bicester uk
    I'm hoping someone can help me with a problem with my Audi A8 D3 2004 3.0tdi. The engine lost power and would not accelerate, seemed to be in limp mode. Glow plug light on dashboard is flashing and the gear box would not change up gear properly, had to use tiptronic to change manually. I've got VCDS and it points to a turbo control circuit problem (see auto scan), but there are several other fault codes which were not present before.
    Monday,02,April,2012,19:06:03:43197
    VCDS Version: Release 11.11.2 (x64)
    Data version: 20120126
    Chassis Type: 4E0
    Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
    46 47 4F 52 53 55 56 61 62 72 76 77
    VIN: WAUZZZ4E05N008145 Mileage: 295550km/183646miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    38-Roof Electronics -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H01--- Serial number: AUX3Z0D8150006
    Coding: 0011973
    Shop #: WSC 00640 210 175173
    VCID: 2952869B80E203B
    3 Faults Found:
    006248 - Transmission Mount Valve 1 (N262)
    P1868 - 001 - Short to Plus
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 295475 km
    Time Indication: 0
    Date: 2004.03.28
    Time: 17:48:51
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.55 V
    Bin. Bits: 00101100
    Torque: 89.7 Nm
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 - 005 - Electrical Malfunction
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 295475 km
    Time Indication: 0
    Date: 2004.03.28
    Time: 17:51:17
    Freeze Frame:
    RPM: 693 /min
    Torque: 89.7 Nm
    Speed: 0.0 km/h
    Temperature: 83.7°C
    Duty Cycle: 80.9 %
    Voltage: 13.15 V
    Duty Cycle: 88.8 %
    000564 - Boost Pressure Regulation
    P0234 - 001 - Limit Exceeded (Overboost Condition) - MIL ON
    Freeze Frame:
    Fault Status: 11110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 295476 km
    Time Indication: 0
    Date: 2004.03.28
    Time: 17:53:56
    Freeze Frame:
    RPM: 2226 /min
    Torque: 487.5 Nm
    Speed: 97.4 km/h
    Absolute Pres.: 2182.8 mbar
    Absolute Pres.: 2580.6 mbar
    Mass Air / Rev.: 1180.9 mg/str
    Temperature: 28.8°C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E0 910 156 F HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0070
    Revision: --H01--- Serial number: 0051956
    Coding: 0000001
    Shop #: WSC 02313 785 00200
    VCID: 254A8AABECFA27B
    No fault code found.
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
    Component: ESP 5.7 allrad H44 0510
    Coding: 0008357
    Shop #: WSC 02313 000 00000
    VCID: 224091B7FDD4D03
    1 Fault Found:
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131
    Component: FBS AUDID3 H04 0140
    Revision: 01404004 Serial number: AUX3Z0D8150006
    Coding: 0265216
    Shop #: WSC 02311 785 00200
    VCID: D8B4735F6B08CA3
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 223
    Mileage: 294880 km
    Time Indication: 0
    Date: 2012.03.29
    Time: 14:58:20
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4E0 910 760 C HW: 4E0 959 760
    Component: Sitzmemory BFS H08 0060
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 4063328
    VCID: 234E94B3E2CED9B
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 730 HW: 4E0 035 729
    Component: Interfacebox H43 0890
    Revision: 00000000 Serial number: 343IM047540443
    Coding: 0000002
    VCID: DDBA624B042A2FB
    Part No: 4E0 910 609 A
    Component: Bedienteil MMI H42 0020
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 016 0340
    Revision: 00000027 Serial number: 00000000052984
    Coding: 1067009
    VCID: 1B3EAC53DABEE1B
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
    Component: ILM Fahrer H12 0190
    Coding: 0023001
    VCID: 2F666883BE066DB
    Subsystem 1 - Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000035
    Shop #: WSC 02313
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00139548
    Shop #: WSC 02313
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655 G
    Component: Airbag 8.4E+ H10 0940
    Coding: 0431707
    VCID: E3CE54B3224E19B
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0112141
    VCID: E5CA4AAB2C7A67B
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
    Component: KOMBIINSTR. VDO H49 0200
    Revision: D03 Serial number: AUDID3D8000499
    Coding: 0000428
    Shop #: WSC 00340 067 57207
    VCID: 275680A396F635B
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
    Component: Heizgeraet H07 0100
    Revision: 0000000B Serial number: 00000009006406
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 1A30A957D584983
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 HW: 4E0 907 468 A
    Component: Gateway H07 0070
    Revision: 07 Serial number: 16003047210CED
    Coding: FCFE7BDE2B3104
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 C HW: 4E0 035 111
    Component: CD-Changer H44 0340
    Revision: 00000000 Serial number: AUZ5ZBD4029667
    VCID: 1932B65BD08293B
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0265216
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 223
    Mileage: 294880 km
    Time Indication: 0
    Date: 2012.03.29
    Time: 14:58:20
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
    Component: LUFTFDR.-CDC H06 4480
    Coding: 0015510
    VCID: 2854839F9BE83A3
    2 Faults Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 236
    Mileage: 294296 km
    Time Indication: 0
    Date: 2012.03.24
    Time: 05:39:15
    01780 - Sensor for Vehicle Leveling
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 227
    Mileage: 294956 km
    Time Indication: 0
    Date: 2012.03.30
    Time: 05:39:32
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H08 0060
    Coding: 4063330
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
    Component: MNS ECE H43 1060
    Revision: 00000000 Serial number: 353IW047567605
    VCID: 3B7E4CD37A7E81B
    3 Faults Found:
    02261 - Data Medium
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 7
    Fault Frequency: 10
    Reset counter: 196
    Mileage: 293464 km
    Time Indication: 0
    Date: 2012.03.06
    Time: 13:45:23
    Freeze Frame:
    Hex Value: 0x4067
    Hex Value: 0x2084
    Hex Value: 0x0000
    Hex Value: 0x0010
    03183 - Data Media not Compatible
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 196
    Mileage: 295496 km
    Time Indication: 0
    Date: 2004.03.28
    Time: 18:05:25
    Freeze Frame:
    Hex Value: 0x4067
    Hex Value: 0x20E4
    Hex Value: 0x0000
    Hex Value: 0xFF94
    02927 - DVD Read Error
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 11
    Reset counter: 236
    Mileage: 295475 km
    Time Indication: 0
    Date: 2004.03.28
    Time: 17:52:39
    Freeze Frame:
    Hex Value: 0x4067
    Hex Value: 0x20CC
    Hex Value: 0x0201
    Hex Value: 0x0000
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H02 0090
    Serial number: 00000415600290
    Coding: 0035840
    VCID: 1D3AA24BC4AAEFB
    Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
    Component: Türsteuer.FS BRM002 0060
    Coding: 0028450
    VCID: 20449BBFF3D8C23
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040409220024
    Coding: 0000249
    Part No: 4E0 910 853
    Component: Heckdeckel P14H06 0070
    Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
    Component: DSP-Amp.-High H13 0360
    Revision: PROD_01 Serial number: 00000000006413
    Coding: 0000013
    VCID: 21429EBBF8D2CBB
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 232
    Mileage: 293404 km
    Time Indication: 0
    Date: 2012.03.06
    Time: 08:51:42
    02454 - Microphone Unit (in Front Roof Module) (R164)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 17
    Reset counter: 192
    Mileage: 293356 km
    Time Indication: 0
    Date: 2012.03.04
    Time: 13:08:57
    Freeze Frame:
    Bin. Bits: 01
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
    Component: ILM Beifahrer H09 0040
    Revision: Serial number: 00000000047556
    Coding: 0010101
    VCID: 1E38A547C9ACF43
    Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
    Component: Türsteuer.BF BRM002 0060
    Coding: 0028450
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 00340 210 82494
    Address 55: Xenon Range Labels: None
    Part No SW: 4E0 910 357 HW: 4E0 907 357
    Component: Pre-AFS H01 0040
    Revision: 00000001 Serial number:
    Coding: 0000002
    VCID: E2C051B73D54103
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 C HW: 4E0 035 541 B
    Component: TUNER EU/US/RDW H41 0290
    Revision: 00000000 Serial number: 304IL047601780
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: J0644 BEM H11 0510
    Shop #: WSC 00340 210 01205
    Subsystem 1 - Part No: 4E0 915 105 A
    Component: von VA0 1409140148
    Coding: 344530393135313035412056413031343039313430313438
    Shop #: WSC 00000 128 00289
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
    Component: Türsteuer.HL BRM002 0060
    Coding: 0028450
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
    Component: Türsteuer.HR BRM002 0060
    Coding: 0028450
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
    Component: Parkhilfe 8-Kan H12 0020
    Revision: --.--.-- Serial number: 08730425102867
    Coding: 0001008
    3 Faults Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 173
    Mileage: 293363 km
    Time Indication: 0
    Date: 2012.03.05
    Time: 10:34:31
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 293363 km
    Time Indication: 0
    Date: 2012.03.05
    Time: 10:34:32
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 9
    Reset counter: 229
    Mileage: 294144 km
    Time Indication: 0
    Date: 2012.03.21
    Time: 05:14:07
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 D HW: 4E0 862 333 C
    Component: TELEFONMODUL EU 0650
    Revision: 00000006 Serial number: T2AUDX0504H92Z
    Coding: 0000004
  2. Re: A8 3.0TDI Flashing glow plug light
    Mar 2010
    Bicester uk
    Further update, might give someone a clue: The flashing light can be reset by simply turning the engine off and restarting, the car then seems to drive normally unless I exceed about 2200 rpm and the light comes back on and its back into limp mode.
  3. Re: A8 3.0TDI Flashing glow plug light
    st pierre, France
    I just had a similar problem. Car running fine. Stopped for a few minutes.. Then glow plug and limp mode. Only 5 ks from home so I limped. My code was also :
    BUT
    as opposed to 08... I pulled the turbo controller plug (which was suspiciously loose) and manually moved the actuator through full movement and greased the connecting rod with lithium spray grease (just in case). Then i did the actuator tests via VCDS and it was fine.
    Cleared the codes and went for a spin.. Back to normal. We'll see in a few days, but I guess it's worth pulling the plug on the turbo actuator and re-seating and making sure the actuator isn't stuck. Does no harm any way.
    good luck
    wjam
  4. Re: A8 3.0TDI Flashing glow plug light
    Mar 2010
    Bicester uk
    Thanks for the reply wjam, I took the car to an audi specialist and they diagnosed a clogged turbo. They took it off and just run some turbo cleaner through it and it all seems to be ok now. I think they had to do it twice because the first time after refitting the turbo they still had the fault. Glad yours worked out ok.
  5. Re: A8 3.0TDI Flashing glow plug light
    Sep 2010
    manchester
    Hi, I was wondering if you managed to sort this issue out? Ive currently got the same problem with my 2006 a8 tdi. Flashed glow plug light then engine management light and went into limp mode. Been advised its the turbo - actuator related. Taken it to a specialist and advised the actuator is faulty and can be changed - problem is its expensive - 200+ for the actuator itself
  6. Re: A8 3.0TDI Flashing glow plug light
    Mar 2010
    Bicester uk
    Quote Originally Posted by meffe View Post
    Hi, yes the problem was sorted. It turned out to be the controller for the turbo, this is the electrical actuator fitted on the turbo and controls the inlet vanes. I was told by the garage that replaced it that the controller cannot be replaced separately. I phoned Midland Turbo and they confirmed this so I had to buy a new turbo from them at £700. If you have the same problem I would definitely consider Midland Turbo as their service and prices are the best I found.
  7. Re: A8 3.0TDI Flashing glow plug light
    Sep 2010
    manchester
    Hi Guys,
    Just a quick update to say thanks for your help in this matter. I took the car to a specialist in Stockpot - AUDI Doctor. He was the 3rd person to diagnose the fault to the Actuator itself, however, this guy knows what he's talking about as he gave me a full breakdown explanation of the problem, and also said the part was available to replace. Happy to say, the new actuator has now been fitted, and the car is all okay now - no flashing coil light/no engine light - faults gone, and the car has its power back! I just never would have put the fault to this as ive never had a single issue with the car..
    Total cost for parts / labour including diagnostic was £330.00 - 2nd user turbo's (not recommended is £400-500) and NEW was priced at £800.00, so in all its a result.
    Thank you once again for the support..
    Saf
  1. 2006 2.0tdi glow plug light flashing and limp mode
    By ctm73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-08-2016, 09:34 PM
  2. Please Help Glow plug light flashing
    By sunshinekid in forum Octavia
    Last Post: 02-02-2010, 12:29 AM
  3. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  4. a3 flashing glow plug light
    By yalittlebeauty in forum Audi A3 - Archive Topics
    Last Post: 05-02-2009, 10:57 AM
  5. flashing glow plug light
    By imanutter in forum The Commercial Range
    Last Post: 02-12-2007, 07:12 PM
