Thread: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
Results 1 to 8 of 8
  1. VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Apr 2012
    dudley uk
    Hello To All VWAudi Forum Members
    I Have A Problem With A 08 Reg Crafter 109PS LWB Chassis Dropside
    Since owning for the last 6 months And doing 35000 Miles I Can Only Seem To Get 350 Miles From a Full Tank Which I Think Is Pretty Poor And Works Out At 21-22 MPG
    It Makes no difference if its loaded or not , It also seems not as powerful as I thought it would be, its as if it feels restricted/Flat at higher speeds struggling To Reach 85 Mph unless going down a hill and if its going up a hill slows to 60-65 max. I have taken it to 3 Genuine VW Garages And according to them there is no faults Except for a £1250 Replacement Turbo Which Has Not Remedied the problem
    I used to own a LT35 With 300,000 Miles and thought the performance/Fuel Economy would be about the same
    The only advice i have Now been given is to remove DPF And Have a Re-Map At About £700-£900
    Could Anyone Else Advise Me On This Problem Or Guide Me To A Garage That would look At It As VW Dont Seem To Know/Care
  2. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Nov 2011
    wrexham
    hi you say that you have replaced the turbo with a new one? if not here is one way to check it take of the top hose on the turbo and put your fingers in and see if there is any up down or side way movement ( with the engine not running of course) if there is you need a new turbo you can get one from essex turbos for £720 new. not recon. hope this helps john
  3. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Apr 2012
    dudley uk
    thanks johnjaques yes it was replaced at a vw commercial garage Listers of worcester
    I have looked at the turbo and is new from what i can see as the turbo body is very clean Whereas the old one that was on it was rusty colour
    im still at a loss what else could be making it so un economical The only thing i have been noticing recently is it revs at a 1000rpm for a while then returns back to 700/750 rpm and this can happen up to 3 to 4 times a day Im not sure if this is the normal dpf regeneration routine kicking in but 3 to 4 times in a day seems a bit excessive and as sometimes i can travel for hours on motorways im not sure if it is doing this all the time as you only notice when coming to a standstill at traffic lights / roundabouts Etc
  4. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Nov 2011
    wrexham
    mine did that and then made a plonking noise then whet back to normal 750rpm. have you cleaned out your dpf and egr see my other thread for more infomation https://www.vwaudiforum.co.uk/forum/s...-and-high-revs . john
  5. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Jan 2011
    Canterbury England
    Hi, did you ever find a reason for your loss of power and poor fuel economy? We have the exact same problem on a 58 reg Crafter 109. It seems so slow compared to our old LT 109. And it seems to drink fuel. It starts, runs and sounds fine and its only done around 90,000 miles. Just feels like there is no turbo on it! Any help much appreciated! Many thanks in advance.
  6. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Nov 2011
    wrexham
    Quote Originally Posted by vwlt46 View Post
    Yes i did find the problem it was the turbo, to check if its the turbo take off the top hose in front of the turbo and and feel if there is any and i mean any movement up down and in and out if there is new turbo needed cost if you diy about £750 for a om exchange.
    also it could be the air flow meter that's about £100 you will need to hook it up to a vw meter. not the one's you can buy of ebay they dont work on crafters.
    john
  7. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Jan 2011
    Canterbury England
    OK thanks for the info Johnjaques. I will take a look on Monday when i'm back at work. Hopefully its not the turbo thats gone.
  8. Re: VW Crafter Chassis Cab Poor Fuel Economy/Under Powered
    Nov 2011
    wrexham
    well if it ant you will have to go to vw to get there tester on it. and thats £60 there.
    best of luck
    john
  1. A6 poor fuel economy
    By billy g in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-12-2011, 12:18 PM
  2. poor fuel economy
    By mick gracey in forum Polo - Derby - Lupo - Fox
    Last Post: 11-02-2011, 11:39 PM
  3. Please Help A4 1996 Poor Fuel Economy
    By simonb5a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2010, 08:19 AM
  4. Poor Fuel Economy
    By hidnmine in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-10-2009, 01:01 PM
  5. A4 B5 115bhp poor fuel economy
    By gorillamonsoon in forum New Member Introductions
    Last Post: 29-03-2008, 08:42 PM
