Thread: Tyre Pressure Monitoring
  1. Tyre Pressure Monitoring
    Oct 2011
    Gourock, Scotland
    I have an R line Passat. 2010 registered. It has a button beside the gear stick. The manual seems to indicate that adjustments/settings can be made to this, yet the only thing I can seem to achieve is an alarm if I hold the button for around 3 secs. I spoke to the dealer and he said its 'preset' from the factory and only alarms if the pressure drops by a certain amount....................however, what happens if, for example, I get 2 front tyres fitted and they are inflated wrongly, how does it all 'work'?
    John
  2. Re: Tyre Pressure Monitoring
    Up North
    The way it's supposed to work is that you first make sure all 4 tyres are at the correct cold pressure. You then press and hold the button for a few seconds until it beeps. It is then set up. If one tyre goes down it detects a change in rolling radius and brings up an alarm.
    If you have new tyres fitted, always tell them what pressure you want. 99% of the time you will never see a tyre fitter look up what it should be on the chart.
    Even if you get an alarm, jump out, check all the tyres, reset the TPMS and wait for it to go again. It isn't that smart and will sometimes fool itself if you are giving it the beans in wet weather. I found this out after waiting 45 mins for the AA to turn up after mine went off in error.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. Question Tyre pressure monitoring
    By satsu in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2018, 08:27 AM
  2. Tyre Pressure Monitoring System
    By D4D in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 18-02-2013, 09:16 AM
  3. Retrofit Tyre Pressure Monitoring
    By GeoffW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-08-2011, 10:18 AM
  4. Tyre Pressure Monitoring
    By theblacksurge in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-01-2011, 10:48 PM
  5. monitoring tyre pressure advice
    By weepiglet in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 02:28 PM
