Thread: Bluetooth Connection
  1. Question Bluetooth Connection
    Yateley, Hampshire
    I have the phone prep in my car which has been great but recently the phone, a blackberry 9860, has started randomly disconnecting and then re connecting to the car which a bit annoying as it interrupts the phone call and also the music. I have deleted the connection on the phone and set it up again ok but still happens. Sometimes I can travel to work and it is fine and other times it may do this 2 or 3 times which makes me think maybe it is the car and not the phone? Anyone else had a similar problem and if so did you manage to resolve it and how? Thanks in advance.
  2. Re: Bluetooth Connection
    Aug 2009
    Near Lanark
    21 Post(s)
    Mine has done it a few times....It would connect when starting the car, then disconnect by the time I had reversed out the drive, then reconnect at the top of the street.
    That was an Iphone.
    Changed phone and it doesn't happen at all now....although the Iphone didn't do it all the time....it seemed to go through a phase....then stopped.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
    Feb 2010
    staffordshire
    Right I might know the answer to this as I had the same problem as few weeks ago.
    If you have Facebook, twitter, whatsapp or anything like this best thing is to get rid of them if you don't want to go to your accounts and sync on your phone and untick the sync with contacts on any of the apps you have installed.
    Then go to call log and clear your call history.
    Delete the audi bluetooth pairing turn the phone off and back on, repair with the car, mine has worked perfectly since I did this.
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Often, just clearing down the call logs will sort the issue.
    MF.
    Sent from my iPad using Tapatalk HD
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  5. Re: Bluetooth Connection
    Yateley, Hampshire
    Cheers guys! I do use linkedin and whatsapp so i might test it tomorrow by switching off the data to see what happens.
  1. Bluetooth Keeps Dropping Connection??
    By meffe in forum A8 - S8 - V8
    Last Post: 14-11-2010, 12:30 AM
  2. Question Bluetooth Phone Connection
    By sigem10 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-08-2010, 01:16 PM
  3. Bluetooth connection chime
    By engineermk in forum Audi A3 - Archive Topics
    Last Post: 28-01-2009, 04:57 PM
  4. A6 Bluetooth connection
    By PatAvant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-03-2008, 11:14 PM
  5. bluetooth connection codes
    By finn in forum Audi A3 - Archive Topics
    Last Post: 05-06-2007, 06:48 PM
