Thread: Glow plug relay/control unit
  1. Glow plug relay/control unit
    Feb 2009
    I have had some starting issues and was directed towards the glow plugs. After checking them one was gone and so I have changed it. This has not solved my problem so I got some mechanics to look at it. Turns out the glow plugs are not pulling any current. They have suggested replacing the associated relay. I spoke to my local DEALER and they could only help by suggesting I replace the control unit at a cost of £62.
    Getting to the point:
    Does anybody know if the glow plug relay can be replaced and what is the part number, or is it a case of replacing the control unit as the dealer suggested?
    Thanks,
    Jake.
  2. Re: Glow plug relay/control unit
    Norfolk
    The glow plug control unit is the glowplug relay. It is underneath the enginebay fuse box usually. Have you got the correct NGK glowplugs. So many people fit the wrong ones and then damage the contoller.
  3. Re: Glow plug relay/control unit
    Feb 2009
    Thanks for the reply. I think I got a BERU glow plug from eurocarparts. It is the correct part for my car according to their website. It reads the same resistance as the others.
  4. Re: Glow plug relay/control unit
    Norfolk
    read the glowplug section on my web site. You can't fit Beru glowplugs.
  5. Re: Glow plug relay/control unit
    Feb 2009
    Rather naughty of eurocarparts that isn't it? Thanks. I'll replace the BERU one with a JFK before replacing the control unit.
  1. glow plug relay
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2012, 12:31 AM
  2. Glow-plug control unit
    By billcoleman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-12-2010, 06:51 PM
  3. glow plug relay
    By robbie04 in forum Ibiza - Cordoba
    Last Post: 01-06-2010, 01:24 PM
  4. Glow Plug relay
    By Skelts in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2008, 07:16 PM
  5. Glow Plug Relay
    By mattis- in forum Golf MK3 - 1993 - 1999
    Last Post: 21-01-2008, 11:34 AM
