Thread: Audi A4 AJM TDi engine into my AJM MK4 Golf??
  1. Audi A4 AJM TDi engine into my AJM MK4 Golf??
    Duffield, Derby
    I know they sit differently in the engine bay but will the main engine block with all my bits,engine mounts, gearbox etc added make it fit?
    Just purchased a project GT TDi but it needs an AJM engine and I've found a low mile Audi A4 one but need to know if it can fit?
    cheers
  2. Re: Audi A4 AJM TDi engine into my AJM MK4 Golf??
    2009 Post(s)
    After you have removed all the ancillaries from the “base engine” as it is known, you will have to fit the Golf’s oil pump pick up and sump and then build up the A4 AJM with the Golf external parts. The oil filter bracket and oil cooler are the same.
  3. Re: Audi A4 AJM TDi engine into my AJM MK4 Golf??
    Duffield, Derby
    Cheers for the reply. Think I'm going to chicken out and spend a bit longer hunting for a Golf AJM engine so its an easier swop as its my first engine change. It's a project car so I'm in no rush.
  4. Re: Audi A4 AJM TDi engine into my AJM MK4 Golf??
    May 2007
    Lanarkshire
    by spooky coincedence I was looking at Golf AJM engine to stick in my Audi A4. I don't suppose I could help you out by taking your unwanted Audi engine off your hands ??
  5. Re: Audi A4 AJM TDi engine into my AJM MK4 Golf??
    Duffield, Derby
    Hello
    I never got the engine but this is the one I was going to buy..
    http://www.ebay.co.uk/itm/Audi-A4-20...c#ht_508wt_952
    I've now found a Golf AJM engine and it arrives Monday night
  6. Re: Audi A4 AJM TDi engine into my AJM MK4 Golf??
    May 2007
    Lanarkshire
    Ta for the link, I must have missed that one, but will do a bit more digging and try and get one nearer home that I can see/hear running first.
  1. Please Help Problem with Golf MK4 Diesel PD engine code AJM
    By marathon in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2013, 04:27 PM
  2. UNDER BONNET WIRING DIAGRAM NEEDED - Golf Mk4 Gttdi 115 AJM
    By NAZZA69 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-03-2013, 08:31 PM
  3. Please Help golf mk4 gttdi 115 ajm engine code
    By biny786 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-02-2012, 03:35 PM
  4. Golf GT TDI AJM engine Mount breakage
    By cardend in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2009, 10:02 AM
  5. A4 Tdi 1.9 Ajm Engine Misfire 2000 W
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2008, 01:33 AM
