Thread: Audi A3 keeps getting stuck in reverse gear
Results 1 to 9 of 9
  1. Audi A3 keeps getting stuck in reverse gear
    Jun 2009
    Carlisle UK
    My friend has an 56 Plate Audi A3 1.9 TDI. They have only had it a few weeks but three times now it has got stuck in reverse gear. Only way to get it out is switch off the engine etc.
    Anyone any ideas what the problem could be?
    Lee
  2. Re: Audi A3 keeps getting stuck in reverse gear
    46 Post(s)
    I noticed in my 2009 1.9 TDi when reversing it won't allow you to take it out of reverse until stationary.
    Don't know if this is what you're describing though.
  3. Re: Audi A3 keeps getting stuck in reverse gear
    Jan 2012
    Coding Something
    Assume its a dsg, could be the gear unit that has the gearstick attached or the dsg lock/barrel has a glitch, although the latter shouldnt take effect until its in park, but hey nothings impossible.
    You can actually get your finger into below the gear gaitor & push on a microswitch that sits below the gear lever when its in park to test if this is functioning ok.
  4. Re: Audi A3 keeps getting stuck in reverse gear
    Jun 2009
    Carlisle UK
    Its just a standard manual 5 speed box. This happens when the car is completely stationary.
  5. Re: Audi A3 keeps getting stuck in reverse gear
    Jan 2012
    Coding Something
    Really, manual stuck in reverse, thats gotta be mechanical then, clutch issue maybe, so no amount of clutch movements will free it?
  6. Re: Audi A3 keeps getting stuck in reverse gear
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    There is a possibility the Clutch is not clearing the Flywheel when the pedal is depressed, causing transmission of drive through the geartrain. Does the car` creep` when the pedal is depressed? (no brakes applied!) If so, drive is still going through the box.
    Alan.
    VW T6 150 DSG Camper £££
  7. Re: Audi A3 keeps getting stuck in reverse gear
    Oct 2019
    Cardiff
    OMG please tell me this is not a common issue for Audi A3 🙈 I have only just bought the car and I have this problem...stuck in reverse! It happens only in the morning 1st thing...I had to stall the car to try and get it out of gear and took 10 attempts. Then it wouldn’t go into gear at all! After waiting 15min I had to put the car into gear with the engine off then start it. Managed to get it going then after 15 min it was all OK...this has happened every day so I’ve sent the car back as I’ve only had it a few days.
  8. Re: Audi A3 keeps getting stuck in reverse gear
    Dec 2008
    I know this is an old thread but what was your outcome.
    My mums a3 tdi is doing just this .
    Engine off and it will come out .
    I've heard of shims you can pop onto the end shafts,,,might be for a different problem though.
    My mums mechanic has quoted her £2000 for a new gearbox and clutch etc
    Her cars not even worth that 🙄
  9. Re: Audi A3 keeps getting stuck in reverse gear
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    This usually happens when the clutch fails to disengage properly.
    The engine is still trying to put power through the gearbox & stopping the gears from being able to be moved.
    That's why turning off the engine then frees the gearbox off.
    Could be the clutch is worn out, could be a leak in the clutch hydraulics, master cylinder/ slave cylinder or hydraulic pipe leaking.
    I think you may need to find a more competent mechanic.
  1. Difficult to select first gear and reverse. Car shudders in reverse
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 11-04-2010, 06:46 PM
  2. Question Reverse light stuck on
    By the surfer in forum Golf MK5 - 2004 - 2009
    Last Post: 10-04-2009, 12:48 PM
  3. Reverse Gear
    By Greenfield in forum Beetle 2000-
    Last Post: 10-11-2008, 01:56 PM
  4. Car gets stuck in reverse??
    By Lis in forum Chat - Anything with wheels
    Last Post: 01-08-2008, 10:23 AM
  5. audi 80 2.0E stuck in 3rd gear (possibly limp mode)
    By whataripper in forum 80 - 90
    Last Post: 27-02-2008, 03:06 AM
