Thread: Engine stalling at junctions or when slowing down
  1. Engine stalling at junctions or when slowing down
    Jan 2010
    Haslemere UK
    HI Please can you help. I had the clutch replaced and now the car is stalling when slowing down or stopping at junctions which makes the power steering and brakes seize. Is the clutch dragging (that is what someone suggested) and how can I fix it. Many thanks, Louise
  2. Re: Engine stalling at junctions or when slowing down
    134 Post(s)
    2021 Post(s)
    Hello Louise. Can you tell us the year of your Golf 3 and the engine code or at least the CC and if it is diesel or petrol?
  3. Re: Engine stalling at junctions or when slowing down
    Jan 2010
    Haslemere UK
    Dear Crasher, thank you for replying. The car is an estate 1997 engine size 1984cc engine no. AGG118516. I am sure that it is not an idling problem but something to do with the clutch. Also I have noticed that there is a squeaking noise intermittently when pressing the pedal.
  4. Re: Engine stalling at junctions or when slowing down
    134 Post(s)
    2021 Post(s)
    Is it difficult to get the car into gear? If not I can't see it being a dragging clutch. What I suspect is that they have disconnected the battery (which is the correct thing to do) which loses the engine computers learnt values that account for the engine and components ageing. After disconnecting the battery the throttle body has to be re-adapted to the ECU using a diagnostic computer and I suspect this has not been done. Also the throttle body may need removing and cleaning.
  1. 1.9 TDI stalling at junctions....
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-09-2010, 09:33 PM
  2. Replies: 16
    Last Post: 17-12-2009, 08:58 AM
  3. A8 stalling at junctions??
    By djpascoe in forum A8 - S8 - V8
    Last Post: 04-07-2009, 06:16 PM
  4. Engine dies when slowing to a stop
    By polowner in forum Polo - Derby - Lupo - Fox
    Last Post: 20-03-2009, 06:44 PM
  5. Please Help Stalling at junctions due to rough idle/missfire
    By tonyrobbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2009, 09:03 PM
