Thread: Touran rear brake piston
  1. Touran rear brake piston
    May 2010
    Otley, West Yorkshire
    I'm having problems winding back the rear brake piston on my 2004 Touran. The piston rotates and appears to be free because it's out further than when I started. I'm trying to use a wind-back tool, but it's not working. Everything seems to be in line, but it seems that it needs more force than I can exert to get the piston to wind back in. Can anyone help?
  2. Re: Touran rear brake piston
    131 Post(s)
    1978 Post(s)
    They can need some serious force if the pads and discs were badly worn so the piston came out a long way and the piston can tilt, making it very hard to push back.
  3. Re: Touran rear brake piston
    May 2010
    I finally worked out that I was turning the piston in the wrong direction! I got the wind-back tool that was recommended on the supplier's website and it turned out to be the wrong one. I eventually managed with a bodge using water pump pliers to turn the piston and a ratchet to lever the piston back. A bit awkward, but once I'd sussed the technique it only took me an hour to complete both sides. Thanks for the advice though.
  1. Rear brake piston problem
    By Leech71 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-11-2010, 10:32 PM
  2. Please Help Brake Piston Question on Replacing rear discs
    By muchos04 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2009, 07:31 PM
  3. Please Help Rear Brake piston rubber dust covers
    By 737-800 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2009, 10:15 PM
  4. Touran Rear Brake Pads
    By dusty in forum Touran - Sharan - Caravelle
    Last Post: 07-07-2008, 12:05 AM
