Thread: trying to bleed water system on my 2.4 v6 petrol
  1. trying to bleed water system on my 2.4 v6 petrol
    Mar 2012
    birmingham
    Can any one help im trying to bleed the water system on my audi 2.4 v6 petrol convertible i cant get the heaters to blow warm after i have changed the cambelt and new thermostat.any ideas thanks
  2. Re: trying to bleed water system on my 2.4 v6 petrol
    Aug 2011
    Hornchurch
    Not sure if its the same as the 1.8T but the 2 pipes going to the heater matrix (Under plastic covers by battery) the left hand one needs to be pulled back enough to reveal the blow hole, when water starts coming out then the system is bled. If it doesn't work then it Could be a water pump problem not pushing the water to the matrix
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  3. Re: trying to bleed water system on my 2.4 v6 petrol
    Mar 2012
    birmingham
    what do you mean blow hole ,like a bleed screw and the i have replaced the water pump with a new one
  4. Re: trying to bleed water system on my 2.4 v6 petrol
    Aug 2011
    Hornchurch
    imagine the tube with the pipe over it, when you pull the hose back (like a sausage skin ) there is a little hole drilled in the metal pipe (I just call it a Blow hole as it reminded me of a whale, i'm strange, i know!! ) when that is revealed it allows air to escape. it does on the 1.8T anyway.
    Hope this helps.
  5. Re: trying to bleed water system on my 2.4 v6 petrol
    Mar 2012
    birmingham
    ok thanks for that do you know weather its the top or bottom pipe cheers
  6. Re: trying to bleed water system on my 2.4 v6 petrol
    Mar 2009
    ok bled the system know let the car run to temperture and still colf air from the heater blowers but both hoses to the matix rerally warm but expansion tank water is cold any ideas
  1. How to bleed out air from the cooling system on a 1.9TDI?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 29-01-2019, 02:28 AM
  2. bleed screws in cooling system
    By chimo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2010, 09:28 PM
  3. air bleed screws in cooling system
    By chimo in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2010, 12:09 PM
  4. Please Help Oil in water system 1600 petrol
    By bollockchops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2010, 05:50 PM
  5. How to bleed Hydraulic roof system golf cabrio
    By Hitby in forum Golf MK3 - 1993 - 1999
    Last Post: 18-06-2009, 12:30 PM
