Thread: Dim headlight 02 Jetta (bora uk)
Hybrid View
  1. Dim headlight 02 Jetta (bora uk)
    Jul 2007
    The Gulf Coast of Alabama,USA
    I have a dim left side headlight on my jetta. Originally I thought the bulb was bad so I replaced it. The light came on bright so I thought, problem solved. Since then, light is on but very dim. I removed and reinstalled the bulb thinking bad connection. Light came on normal. Switched to high beam, good. Back to low beam, back to dim. When I switch to high beam now, the bulb gets even dimmer (almost out) then returns to the dim look. I have been to the grounds under the battery box and actually removed and cleaned before reinstalling. Also checked the ground on the steering column under the dash but no change. Could I be looking at a bad relay?
  2. Re: Dim headlight 02 Jetta
    Jul 2007
    One more thing that may be of help. The daytime driving lights are the same as night time, left side dim, right side normal.
  3. Re: Dim headlight 02 Jetta
    Jul 2007
    Changed the daytime light relay today. It didn't help. While troubleshooting I came across what I think is an odd condition. The leftside bulb connector only has voltage on one hot wire at a time depending on high or low beam. Normal, right? The right side connectors however are both hot always regardless of high or low beam switch position but the headlight still gets brighter on high and lower on low. How'd they do that?
  4. Re: Dim headlight 02 Jetta
    neileg Guest
    Sounds like an earthing problem to me.There are three terminals on the bulb since high and low beam have a common earth. If the earth is poor or non existant, the supply voltage to one filament will appear on the other supply terminal.
    The earthing problem is likely to be at the headlamp unit itself, rather than in the switchgear.
  5. Re: Dim headlight 02 Jetta
    Quote Originally Posted by neileg View Post
    i agree... check your earths.
  6. Re: Dim headlight 02 Jetta
    Jul 2007
    Can you tell me where the earth positions for the headlamps are located on the car itself. As I said before, I have already been under the battery box and all are good. Also checked ground under steering column. Thanks in advance for any help you can lend.
  1. VW Bora / Jetta Camber Kit
    By boooosted in forum Bora - 1998 - 2005
    Last Post: 16-04-2008, 11:19 AM
  2. 2001 VW JETTA V5 South-Africa (bora in uk)
    By dok555 in forum Bora - 1998 - 2005
    Last Post: 28-11-2007, 04:10 PM
  3. 2000 Jetta 2.0 Engine Fault (bora uk)
    By Dorritt in forum Bora - 1998 - 2005
    Last Post: 14-08-2007, 04:16 PM
  4. Golf-Jetta-Vento-Bora engines and size
    By Snowdance38 in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-07-2007, 02:39 AM
  5. Golf -Vento -Jetta - Bora
    By stuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-04-2004, 10:56 PM
