Thread: Audi bodywork warranty
Results 1 to 10 of 14
  1. Audi bodywork warranty
    Jan 2012
    Buckingham
    Hi guys
    Have noticed that there is a small rust type bubble on the front wing
    It I'd about the size of a 5 pence piece and when pressed feels lie water is underneath, what is the bodywork warranty on Audis it's a 2005 a4 S-Line avant
    Sent from my HTC Desire HD A9191 using Tapatalk
  2. Re: Audi bodywork warranty
    Feb 2012
    Bradford
    According to my documents that came with my car, Audi A4 2005 (B7), you get 3 years warranty on the paint and 12 years warranty on anti corrosion. Hope this helps mate. Tbh, I would recommend you contact your local Audi Delaer
  3. Re: Audi bodywork warranty
    Dec 2011
    gwynedd
    If the Audi 12-Year perforation Warranty is similar to VW you will need a dealer with an Approved Audi Bodyshop. In the first instance I would contact Audi Customer Care and register your problem and have the name of the contact and ask for a Complaint Reference number. They should advise you to have it inspected at an Audi Dealer. They will check the paint thickness to show any repairs which would invalidate any warranty claim on that wing. The bubbles are a sign that the metal is perforated requiring wing replacement. Hopefully you will not have to put up with the hassle and wriggles that VW dealers and Customer Care have used to avoid paying for repairs.
    Remember the 12 year Warranty has no conditions, does not require a Full Service History and is valid for all owners up to 12 years. You must not be put off by offers of contributions to the work of anything less that 100%, offers of a Goodwill contribution to the repair or that the paint Warranty was only for 3 years. Be polite but persistent and you will be rewarded with a new wing and a courtesy car while it is being fixed. If the bubbles are at the top of the wheel arch it will probably be due to a shaped acoustic foam pad that sits between wheel arch liner and underside of wing. It can vibrate and with the dust and dirt between the foam edge and the wheel arch....eventually removes the galvanized coat to bare metal and the rest is history. It affects Golfs and Passats from certain years. VW and their dealers are fully aware of the problem as a Worldwide bulletin has been issued.
    1 1 0
  4. #4
    Jan 2012
    Buckingham
    Had it looked at and Audi dealer has suggested maybe a attempt at a good will deal for the front wing as it looks more like a paint defect but have noticed rear arch has started a little but after paint tests and checking its had a paint job on the rear quarter so they won't cover that
    Where do I go to attempt a good will claim ?
  5. Re: Audi bodywork warranty
    Dec 2011
    gwynedd
    If your wing etc has been resprayed it will not be covered by any goodwill as it is out of the 3year paint defect part of your original Warranty. You do not want to make a Goodwill claim if your wing has developed blisters at the top of the front wheel arches as this is covered by your 12 year body 'perforation/corrosion' Warranty which if your wings etc meets the criteria you will be entitled to replacement or repair. If it has reached the perforation stage shown usually by blisters that tend to swell up in the sun then your wings will be replaced at no cost to you. However VAG will offer you a 'contribution' of anything from 30% up to 100% in an attempt to reduce their costs.
    There is a document on the internet that outlines the problem with Golf and Passat wings that is worth reading. I am not familiar with Audi but there may be a similar problem with Audi wings. Whatever...... be prepared for a battle with VAG as they will try and wriggle off the hook!
    Jan 2012
    Buckingham
    I was informed by the Audi bookshop that the bubbles wouldn't be covered under the corrosion or perforation warranty but may come under the paint defect but as its over the 3 yrs then I'd have to fight a good will claim or I might just leave it and get it sorted when it gets worse
    Jan 2012
    Buckingham
    Picture of said defect/corrosion
  8. Re: Audi bodywork warranty
    Dec 2011
    gwynedd
    http://www.vwgroup-paintandbody.co.u...5FrontWing.pdf
    If you have not seen this before it is worth downloading as it shows the extent of the problem that affects both Passats and Golfs of various ages. It seems to take a while to load but be patient as it is worth it. Whether it applies to Audi I do not know but if you have the blisters it is the same problem which will be covered by your 12 year Corrosion Warranty.
    DO NOT CLAIM UNDER ANY DEALER OFFER OF A GOODWILL CLAIM. You already have your 12 year Corrosion Warranty!
    Jan 2012
    Buckingham
    Brilliant many thanks chipped3 will go to Audi armed with this and see what they fight back with
  10. Re: Audi bodywork warranty
    Jul 2013
    durham
    hi.
    My 03 a4 avant has a lot of corrosion on both front wings, drivers side is much worse and it appears to be bubbling through from underneath. I took it to local audi dealer and asked if it was cvered by the warranty. The guy took measurements of the paint thickness and then said that the wing wasnt original. It is an original wing and surely if the paint is thinner than it should be, this would be due to the fact its corroding? possibly. Anyway audi have offered a 70% goodwill payment. This still means that i will have to find 350 quid to get the wings replaced. Just seems a bit of a rip off when the y gave a 12 year warranty.Who should i contact to try and get the full cost of the repair? the garage again or audi head office?
  1. Warranty for used Audi
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-08-2010, 11:13 AM
  2. 05 Audi front bodywork damage
    By Petermack in forum Audi A3 - Archive Topics
    Last Post: 03-03-2009, 02:45 AM
  3. Audi Warranty
    By Moro Anis in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-02-2009, 04:04 PM
  4. Audi Warranty
    By GRAHAM747 in forum Chat - Anything with wheels
    Last Post: 02-02-2009, 11:18 AM
  5. audi warranty
    By saif786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-12-2008, 08:08 AM
