Thread: 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
  1. 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    May 2008
    darlington
    hi, i have the 2.5tdi ake engine and it had a diesel leak around all 3 of the injectors on the right bank, so i changed the leak off pipes but they are soaking again with fuel not oil, what could be the problem ?
    the new pipes are of good quality and are a nice tight fit.
    if it was the injector seals leaking would it be an oil leak or fuel leak ?
    im thinking the leak could be coming from the injector seals.
    i will buy more new/different fuel line but i feel it isnt that that is the problem, maybe too much pressure ???
  2. Re: 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    Douglas Isle of man
    I have the same problem on the right side to. I have replaced the pipes twice. I tightened the small bolts holding on the nipples. I think now it leaks from one. I am going to replace the washers on them. I am guessing they are copper washers. If this doesn't fix the problem how difficult is it to seal the injector properly? Can I just nip it up?
  3. Re: 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    Jun 2008
    Beverley, east Yorkshire
    They are renound for leaking here, i changed mine 3 or 4 times before i got it leak free.
    A4 AVANT 2.5TDI SPORT QUATTRO
  4. Re: 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    May 2008
    darlington
    now fixed , i changed them again and tightened up the bolts underneath them.
  5. Re: 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    May 2008
    darlington
    no longer fixed , somone came to buy the car tonight and the starting problem came back !! I DONT BELEIVE IT !
  1. Audi A4 Diesel Fuel Pump leak - AFN engine
    By chris_miller in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2014, 10:06 PM
  2. Changing fuel leak off pipes
    By Mike Smith in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-10-2010, 06:08 PM
  3. Diesel Fuel Filter Leak - doh!
    By waaarp in forum Golf MK4 - 1999 - 2004
    Last Post: 29-06-2010, 01:51 PM
  4. Question 94-TDI Fuel leak around injector pump?
    By Timk in forum 80 - 90
    Last Post: 03-08-2009, 06:30 PM
  5. temp gauge water leak, fuel leak all sorted
    By a6rom in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-02-2009, 12:44 PM
